Cyclone PCB Factory/build
Revision as of 14:17, 27 July 2015 by Tatubias (talk | contribs)
In this section i will be quick showing more or less how the mechanics should be assemble
Here you can see more or less all the basics parts that you need. You can see all printed parts. also nuts, screws, rods, stepper motors, drivers, etc
First cut and drill the base. i did sent them to laser cut and laser drill to avid miss aligments. Then paint them with the color that you want. i did use MDF wood. Glue with silicon Rubbers to avoid nuts scratch the table surface.
put the bolts and nuts to the 2 laterals and tight them not to much we need them lose so later we can align all the machine.
The add the support for the Y axe
Put nuts and bolt to the y rods support. left them little lose so then you can align them with the machine structure.
20150727 114733.jpg Note: here i recomend to install the end stop, the it will be more complicated to do this.
