EMAKER Huxley
Revision as of 11:11, 22 January 2011 by Jmgiacalone (talk | contribs)
EMAKER Huxley
Release status: experimental
Description | |
License | unknown
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
This is a redesigned Huxley inspired by the Prusa simplified Mendel.
Files (Coming Soon!!!)
FILE ID# | TYPE | DESCRIPTION | AVAILABLE FORMATS | CREATED/RESERVED BY |
Your-File-Name | SOLID MODEL ASSEMBLY | These are CAD files for the Solid Model Assembly | .xml.zip, .stl.zip | --Example User 12:00, Today's Date 20xx (UTC) |
eMAKER Huxley STLs] | STL FILES FOR PARTS | These are STL files for each part. | .xml.zip, .stl.zip | --Example User 12:00, Today's Date 20xx (UTC) |
Your-File-Name | SOLID MODEL ASSEMBLY | This is the final finished machine | N/A | --Example User 12:00, Tomorrow's Date, 20xx (UTC) |
Please edit this and click the links to put in your own files! --Sebastien Bailard 08:34, 10 September 2010 (UTC)
History
Bill of Materials
Printed Parts
2x coupling RP 1x y-endstop-holder RP 1x z-endstop-holder RP 1x x-carriage RP 1x x-end-idler RP 1x x-end-motor RP 1x y-motor-bracket RP 1x y-idler-bracket RP 2x z-motor-mount RP 1x belt-clamp RP 1x belt-nut-trap RP 8x bar-clamp RP 2x drive-pulley RP 2x idler-pulley RP 3x opto-flag RP 1x nozzle-holder RP 4x frame-vertex with foot RP 2x frame-vertex RP
FOR THE EXTRUDER DRIVE
1x M4-extruder-block RP 1x beefed-up-idler-pulley RP 1x 9tooth-gear RP 1x 53tooth-gear RP
Printed Bushings
11x pla-bushing RP-PLA
Non-Printed Parts ("vitamins")
2x Nema 14 bipolar stepper motor, 14Ncm 2x Nema 14 bipolar stepper motor, 6Ncm 50x Small cable binder/ziptie Misc. 1x Electronics + endstops. This can be RAMPS,Pololu Electronics,Gen6,Gen3,or anything else compatible
(The eMAKER Huxley uses the 4 drivers in the standard Mendel electronics package to drive 5 motors by using "two steppers wired in parallel to one driver"[1]).
Printing the Parts
Buy the printed parts
Coming soon to eMAKERshop
