EMAKER Huxley
Revision as of 11:20, 22 January 2011 by Jmgiacalone (talk | contribs)
EMAKER Huxley
Release status: experimental
unknown
This is a redesigned Huxley inspired by the Prusa simplified Mendel. The information on this wiki page is not yet complete, so do not attempt to build this machine. I will keep updating this page over the next few days until there is enough information on here for a complete build of the eMAKER Huxley design.
Files
Your-File-Name SOLID MODEL ASSEMBLY These are CAD files for the Solid Model Assembly N/A --Example User 12:00, Today's Date 20xx (UTC)
EMAKER huxley 00 STL FILES FOR PARTS These are STL files for each part. .stl.zip --jmgiacalone 12:00, Today's Date 20xx (UTC)
Your-File-Name SOLID MODEL ASSEMBLY This is the final finished machine N/A --Example User 12:00, Tomorrow's Date, 20xx (UTC)
History
Bill of Materials
Printed Parts
2x coupling           RP
1x y-endstop-holder   RP
1x z-endstop-holder   RP
1x x-carriage         RP
1x x-end-idler        RP
1x x-end-motor        RP
1x y-motor-bracket    RP
1x y-idler-bracket    RP
2x z-motor-mount      RP
1x belt-clamp         RP
1x belt-nut-trap      RP
8x bar-clamp          RP
2x drive-pulley       RP
2x idler-pulley       RP
3x opto-flag          RP
1x nozzle-holder      RP
4x frame-vertex with foot RP
2x frame-vertex       RP
FOR THE EXTRUDER DRIVE
1x M4-extruder-block  RP
1x beefed-up-idler-pulley RP
1x 9tooth-gear        RP
1x 53tooth-gear       RP
Printed Bushings
11x pla-bushing        RP-PLA
Non-Printed Parts ("vitamins")
2x Nema 14 bipolar stepper motor, 14Ncm
2x Nema 14 bipolar stepper motor, 6Ncm
50x Small cable binder/ziptie       Misc.
1x Electronics + endstops. This can be RAMPS,Pololu Electronics,Gen6,Gen3,or anything else compatible
(The eMAKER Huxley uses the 4 drivers in the standard Mendel electronics package to drive 5 motors by using "two steppers wired in parallel to one driver"[1]).
Printing the Parts
The assembled eMAKER Huxley prototype
Buy the printed parts
Coming soon to eMAKERshop
Test Videos
XY axes test
First print
