File:MKS BASE PINS.pdf
Revision as of 04:03, 8 November 2014 by Leiochen (talk | contribs) (It is the PIN map for MKS BASE seris PCBA.)
MKS_BASE_PINS.pdf(file size: 141 KB, MIME type: application/pdf)
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current04:03, 8 November 2014 (141 KB)Leiochen (talk | contribs)It is the PIN map for MKS BASE seris PCBA.
  • You cannot overwrite this file.
The following page links to this file:
