File:PRUSA i3 steel 3mm lasercut 2.01d irobri.dwg
Revision as of 21:13, 3 December 2014 by AndrewBCN (talk | contribs) (CAD file for Prusa P3Steel, version 2.01. This is released under the same license as Irobri's original .dwg CAD file for version 2.0.)
PRUSA_i3_steel_3mm_lasercut_2.01d_irobri.dwg(file size: 104 KB, MIME type: application/acad)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current21:13, 3 December 2014 (104 KB)AndrewBCN (talk | contribs)CAD file for Prusa P3Steel, version 2.01. This is released under the same license as Irobri's original .dwg CAD file for version 2.0.
  • You cannot overwrite this file.
