File:Y motor bracket.jpg
Revision as of 08:25, 22 May 2011 by ROTORIT (talk | contribs) (The Y motor brackets is also feets to encrease stability in the lower frame at the rods is as long as 500mm. There is 2 of these as there is 2 stepper motors in the y axis.)
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current08:25, 22 May 2011Thumbnail for version as of 08:25, 22 May 2011800 × 600 (272 KB)ROTORIT (talk | contribs)The Y motor brackets is also feets to encrease stability in the lower frame at the rods is as long as 500mm. There is 2 of these as there is 2 stepper motors in the y axis.
  • You cannot overwrite this file.
There are no pages that link to this file.
Metadata
