Firmware/Alternative
Revision as of 00:26, 28 February 2013 by DavidCary (talk | contribs) ("Bézier Approximation of Circle Involute Curves")
This page has been flagged as containing duplicate material that Comparison_of_RepRap_Toolchains also attempts to cover.
These pages should be merged such that both pages do not attempt to cover the duplicate topics.
See also a Comparison chart of Firmwares on page Comparison_of_RepRap_Toolchains
Arduino Test Code
Simple tests to help debug and check your arduino and cartesian robot.
  • pRINToPTO - doesn't move any motors, only prints the status of the opto switches to the arduino IDE terminal.
  • hOMING - brings back all the axes one by one to the home position using only the opto switches as feedback (no sanity checks).
  • rECTANGULARsPIRAL - prints the above rectangular spiral from the current position (no homing). width height and margins are easily modifiable.
YouTube Video of the rECTANGULARsPIRAL program in action.
rECTANGULARsPIRAL action
Download the Test_code.zip file.
Teacup Firmware
Rewrite of FiveD firmware for the Arduino by Triffid Hunter and more. It avoids C++ in favour of plain C, and uses 100% integer math.
curves
Many parts we want to print out have circles and other gentle curves.
Most current firmware only supports extruding straight lines, so the slicer converts those curves into thousands of tiny straight lines -- so small that they can be printed faster than some drip-feeders can send them from the host to the RepRap, leading to buffer underflow.[1] (Other proposals for fixing this buffer underflow problem: #SD card, #alternatives to G-code).
Perhaps it would be better if the firmware implemented some sort of curve -- perhaps the standard
One practical guide to implementing such curves in firmware: Steve Noskowicz. "Interpolation and Curves for Graphics".
A theoretical guide to gear design with Bézier curves: Fumitaka Higuchi, Shuuichi Gofuku, Takashi Maekawa, Harish Mukundan, Nicholas M. Patrikalakis. "Approximation of Involute Curves for CAD-System Processing": "Bézier Approximation of Circle Involute Curves". 2006. </ref>
Then a post-processor after the slicer converts those thousands of tiny straight lines into a few dozen circular arcs (a circular spline) or a handful of B-splines. It should be much easier for the drip-feeder to send a few dozen G codes representing curves through the USB cable than to send thousands of tiny straight lines.
SD card
Most RepRap firmware implements G-code by executing one line at a time as it is "drip-fed" out from a host (perhaps with a small buffer of a few lines).
Some RepRap firmware reads ".gcode" files off a SD card, with no host intervention necessary. The two main approaches:
  • The host sends the an entire layer or perhaps the entire print, and the RepRap firmware saves it to the SD card, which acts as a large buffer.
  • The host saves the ".gcode" file to a SD card, which a person manually carries and plugs into a completely stand-alone printer.
Several people have suggested designing a host-to-microcontroller communication protocol much simpler and easier to interpret than G-code. At the moment, these are all highly experimental, but they could potentially reduce the net cost of a RepRap (simpler protocols can be decoded by lower-cost electronics) and improve the speed and quality of printed parts (less time decoding and interpreting commands may result in more time extruding plastic).
As a first step, and to remain compatible with the many tools that produce G-code, software on the PC can pre-interpret G-code files to produce motion commands in a simpler format, something like the way 3D-to-5D-Gcode.php converts one kind of G-code to a simpler-to-interpret kind of G-code.
  • "Implementing Postscript as firmware" on the RepRap forums.
  • GCODE buffer multiline proposal discusses a small change to the G-code protocol that is forwards- and backwards- compatible.
  • Granite Host
  • EMCRepRap converts most G-code to simple "step, direction" pulses on the PC.
  • SNAPComms
  • Much of the ""Firmware - experimental" RepRap discussion forum discusses protocols that are hopefully easier to interpret than G-code.
  • splines and circles: By describing every move in the form of curved cubic splines, not only do we reduce the volume of data required to describe a curved part, but it may also make the microcontroller firmware simpler and faster. Faster: only integer arithmetic required. Simpler: the firmware only needs a single subroutine to handle cubic splines, rather than several subroutines to handle straight lines, circles, arcs, and the involute curve used for twice for each gear-tooth. Less volume: 8 cubic splines per circle are more than adequate for high precision CAD/CAM machines[2], while apparently (?) the current RepRapGCodes requires hundreds of tiny straight line segments to approximate the same circle. Elegant multispline motion controller and RepOlaRap mention such splines.
  • Flutterwumper Library generally focuses on generating shapes in PostScript format, and then converting directly from PostScript to "step, direction" pulses, without ever going through G-code.
  • ".gcode versus .s3g" discusses the ".s3g" format file produced by replicatorG. It also mentions that USB seems to have high latency.
  • "Bluetooth working, but pauses after each gcode line" says that Bluetooth has even more latency than USB.
