Foton 3Dprinter
Release status: unknown
Description | All-plastic intergrated mechanics
License | unknown
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Overview
The foton 3D printer's is a redesign of the origional Mendel printer currently being developed by Foton labs
The primary goals in the redesign have been to:
- reduce assembly time
- reduce the time and materials demanded in production
- build upon the printers esthetic value.
- reduce the technical barrier to domestic 3D printing
All of which have aimed at making the Mendel printer more accessible to a wider group of people both economically and technically.
Materials
The mechanics of this printer are almost entirely made from a single polyurethane liquid plastic, whilst the fasteners and threaded bar are made from nylon and bearings of stainless steel. Having simplified many of the mechanical parts it is possible to use more commonly found materials such as MDF or plywood for the making of parts, which makes this design well suited for those on a very tight budget with good DIY skills, for those interested images of the parts with their dimensions can be found here.
Production process
The majority of the parts are made from an open coldcasting process, which is both time and cost efficient and opens the printer up to the possibility of mass production, with production time of parts currently down to as low as one hour.
Assembly
Intergrating many of the mechanical parts has led to a large reduction in assembly time and complexity, with assembly time currently bellow five hours. One of the primary aims has been to create a design with as few parts as possible resulting in a quick and easy to assemble printer suited to the no technically minded person.
Distribution
This design is primarily aimed at an "Ikea style" form of distribution, easy to mass produce parts that can be made into a flat pack for shipping and assembled by the average person. This is a classical form of distribution current in the world to day and has many advantages most notably economy of scale. The other form of distribution that this printer also lends its self well to is the self-replicating model and is a medium to long term goal of this design with the possibility of making the frame scalable currently being developed to this end.
Electronics
The mechanics of this printer are designed to work with the standard set of electronics used on a Mendel print,being on a 1:1 scale with the stranded Mendel in size means that there should be no additional alterations to the software or electronics needed.
Current development
The Foton 3d printer is currently undergoing its second phase of redesign, The two areas that are being focused on are:
- continuing with the process of stripping the mechanics down to stream line their production and assembly
- making the printer scalable(expandable frame) and self-replicatable.
1.This is a design that continues with stripping the mechanics down to the most basic requirement, this redesign has essentially done away with the frames vertex supporting the z axes, replacing them with supports at the base of the threaded bars with the advantage of greatly reducing the quantity of materials, the overall weight, the assembly time and complexity, there are many advantages to this that work in continuing to streamline the mechanics. This faze of the redevelopment has been implement on the prototype using mild steel threaded bars and is proving remarkably robust.
2.This is a current design that is being developed for making the printer self-replicating based around dividing the frame up into segments that are all with in a 15/20cm size limit. The design looks at cutting the frame to create a number of joints where in a nylon plastic threaded bar would be placed (see images bellow). The mechanics would then be assemble by screwing larger number of smaller parts them together
with the added advantage of make the printer less ridged than the original design using glue to holed the parts to gather.
This design would increased the complexity and time of assembly and production but it is thought worth it for the added advantages that self-replication would brings.
