Foton 3Dprinter
Revision as of 12:51, 12 August 2010 by Foton (talk | contribs)
Foton 3Dprinter
Release status: unknown
Simplified Mechanics
unknown
Overview
The foton 3D printer's is a redesign of the origional Mendel printer currently being developed by Foton labs.
The designs for this printer are based upon trying to developing a 3D printer that is both technically and economically accessible to as broader spectrum of person as possible. This is seen to be achived thought a design that both simplifies the mechanics to reduce technical complexity and by developing a streamline production process to maintain a low cost per unit end product. The primary factors in the designs of this printer have been:
1. Maintaining a low level of technical complexity for the end user
2. Cost efficiency and commercially
3. Esthetics and form
Materials
Materials
The mechanics of this printer are made predominately form a polyester resin, that provides a low cost solution for the bulk material, with this is added a flexible agent to vary the rigidity or flexibility of the material. Steel is used to provide structural strength, both in the fasteners and for the up right of the frame.
Production process
Casting
The majority of the parts are made from an open cold casting process, which is both time and cost efficient and opens the printer up to the possibility of mass production, with production time of parts currently down to as low as one hour.
Assembly
Intergrating many of the mechanical parts has led to a large reduction in assembly time and complexity, with assembly time currently bellow five hours. One of the primary aims has been to create a design with as few parts as possible resulting in a quick and easy to assemble printer suited to the no technically minded person.
<videoflash type="youtube">BHpA7jZqDeM</videoflash>
Electronics
Elecronics
The development of this printer to date has focused on the mechanics which are designed to work with the standard set of electronics used on a Mendel print, being on a 1:1 scale with the stranded Mendel in size means that there should be no additional alterations to the software or electronics needed.
Distribution
Parts
This design is primarily aimed at an "Ikea style" form of distribution, easy to mass produce parts that can be made into a flat pack for shipping and assembled by the average person. Designs are also being developed to reduce the plastic parts down to a printable size, thus making the printer capable of producing some of its own parts.
Current development
These possible re-designs and any other ideas can be discussed on the forum thread
