Fully printable reprap
Fully Printable Reprap
Release status: concept
Description | A Reprap With the Ability to produce a majority of it's own parts
License | |
Author | |
Contributors | |
Based-on | [[]]
Categories | |
CAD Models | |
External Link |
Introduction
The fully reprappable reprap was designed as the newest iteration of the reprap. It was designed in such a way that it could evolve, grow, and reproduce. It has many iterations ranging from miniature "cupcakeable" unit with a build area of 75mm*125mm devices to "super units" with a build area of 500mm*1000mm and in fact most units can create units that is even larger than themselves!
Advantages
Working Notes.
Everything below this point is working notes.
Parts
These are the parts used to build the fully reprapable reprap.
Downloads
- File:Uploaded files example.zip
- File:Even more example files.zip
- File:Example part.stl
- File:Other example part.stl
Photos and Drawings
Further reading
- Is plastic strong enough to use as frame material? In 2008 MattK was experimenting[1][2] with a frame built mostly from plastic 3/4" ABS pipes in the Development:McWire configuration.
