Generation 2 OnABoard
Release status: Experimental
Description | One board to handle most of the gen 2 electronics.
License | unknown
Author | |
Contributors | |
Based-on | [[]]
Categories | |
CAD Models | |
External Link |
This is a single board that contains most of the electronics required to run a RepRap. All the components that require soldering are through-hole. The cost is slightly less than the generation 2 electronics because there is less need for connectors and PCB space to support connectors.
The board uses the ATMega644P. It can be treated as a Sanguino based Gen 2 electronics and will work with existing firmware that supports the Sanguino.
Schematic
Project Files
File:Gen2OnABoard.tar.gz The project archive contains the gEDA and PCB files.
File:Gen2OnABoard.grb.tar.gz This file contains the latest gerber files, which can be sent to a fabricator.
File:Gen2OnABoard.ps This is black and white postscript file containing each layer. It should be useful for fabricating using a toner transfer method.
Circuit Board
The lower right is an ATMega644P, in a DIP socket. This is the same chip that the Sanguino and the Gen3 motherboard uses. It should be easy to get existing firmware to work with this board.
Near the top I have 4 pololu stepper drivers. See Pololu_Electronics for more information on these boards. Under each stepper driver there are jumpers used to configure the micro-stepping.
On the left side there are three PWM drivers for the fan and two heaters. Each of these can handle 4A continuous, but the total for all three channels can't exceed 8A or the traces that supply them with power might get too hot.
I do not think it will be possible to run a heated bed off from this board. If you wish to try here are my suggestions. Design the heated bed to use no more than 8A (so, at least 1.5 Ohm). When warming up the bed, turn the other two PWM drivers off to limit the total current used by the PWM drivers to 8A. If you exceed 8A, you run a risk of burning the traces on the board. When the bed has reached its working temperature, reduce the PWM duty cycle and then you can use the other PWM drivers as long as you are careful to limit the total average current to 8A. The connectors are only rated to 4A, so you may also want to solder your wires directly to the board. The MOSFET can only handle 4A without a heatsink, so you will have to add a heatsink. If someone tries this, please update this paragraph with your results.
On the right, below the stepper drivers is a 20-pin ATX connector. I'm using the 5V standby to power the microcontroller and I have a pin on the Arduino connected to the power switch wire so that the Arduino will be able to turn the power supply on and off. There is also a 4-pin ATX12V connector to reduce the voltage drop between the power supply and the board.
Between the power connector and the microprocessor there are PTC resettable fuses on each of the 5V and 5V standby lines. These will prevent traces from burning up in the event that something gets connected incorrectly. The 12V and GND lines are not protected in this manor.
The two temp sensors and the AUX sensor have places for a resistor between +5V and the sensor pin. They also have places for a capacitor between GND and the sensor pin. By populating these components it is possible to connect a thermistor directly without using a thermistor board.
I made all the traces that carry significant current thicker. Most of these are 0.05 inch.
Most of the traces on the top half of the board are on the bottom layer with a ground plane filling the top layer.
Since there isn't much going on under the stepper drivers I filled the bottom layer in that area with a +12V power plane. The idea here is to limit interference between the stepper drivers each pulling from the same supply. Since there can be as much as 10A running through the +12V plane, having a wide path also helps to reduce voltage drop.
I'm estimating this will cost about $125 for the prototype board.
To build a RepRap using this board you will also need a USB-ttl cable, 3 or 6 opto-endstop, a fan to cool the stepper drivers and an ATX power supply.
Suggested Improvements
- modify mask to indicate polarity of LEDs and electrolytic caps - correct hole spacing for ATX power connectors - select ATX power connectors and stepper driver connectors without plastic mounting pegs - correct hole diameter for diodes - add R14 560 Ohm resistor to BOM - increase spacing between crystal and 22pf caps, hole spacing between the leads of each 22pf cap can be narrower - crystal, 22pf caps, and resistors will fit in the space beneath the massive Atmega 644p IC. This would save a lot of board real estate - add 5W resistor for power supply load
Part List
The best way to order parts is to go to the thingiverse page linked below. At the bottom there is a suppliers link, which will help you develop a shopping list. If suppliers for your region are missing, feel free to add them to the parts. This will help out other users.
http://www.thingiverse.com/thing:2187/partlist
<iframe width='700' height='1600' frameborder='0' src='http://spreadsheets.google.com/pub?key=tBayPY9TjIrdJSbT1ZLSoaA&single=true&gid=0&output=html'></iframe>
Pin Assignments
usage | Arduino | ATMega644P | Special Function |
X_STEP | D15 | PD7 | PWM |
X_DIR | D18 | PC2 | TCK |
X_MIN | D20 | PC4 | TDO |
X_MAX | D21 | PC5 | TD1 |
X_ENABLE | GND | ||
Y_STEP | D23 | PC7 | |
Y_DIR | D22 | PC6 | |
Y_MIN | D25 (A6) | PA6 | ADC |
Y_MAX | D26 (A5) | PA5 | ADC |
Y_ENABLE | GND | ||
Z_STEP | D29 (A2) | PA2 | ADC |
Z_DIR | D30 (A1) | PA1 | ADC |
Z_MIN | D2 | PB2 | INT2 |
Z_MAX | D1 | PB1 | INT1 |
Z_ENABLE | D19 | PC3 | TMS |
E_STEP | D28 (A3) | PA3 | ADC |
E_DIR | D16 | PC0 | SCL |
E_ENABLE | GND | ||
HEATER1 | D14 | PD6 | PWM |
TEMP1 | A4 (D27) | PA4 | ADC |
HEATER2 | D4 | PB4 | PWM |
TEMP2 | A7 (D24) | PA7 | ADC |
FAN | D3 | PB3 | PWM |
PS_ON | D17 | PC1 | SDA |
ENCODER | D0 | PB0 | INT0 |
AUX | A0 (D31) | PA0 | ADC |
MOSI | D5 | PB5 | MOSI |
MISO | D6 | PB6 | MISO |
SCK | D7 | PB7 | SCK |
RX (Serial) | D8 | PD0 | RX0 |
TX (Serial) | D9 | PD1 | TX0 |
RS485 IN | D10 | PD2 | RX1 |
RS485 OUT | D11 | PD3 | TX1 |
RS485 Tx Enable | D12 | PD4 | PWM |
RS485 Rx Enable | D13 | PD5 | PWM |
