Glossary
Revision as of 11:30, 16 September 2010 by Buback (talk | contribs) (BOM)
Glossary
ABS
Acrylonitrile Butadiene Styrene
A Thermoplastic material which is used in plastic printers from which objects are made from.
Often ABS is used as a short form, actually referring to filament made of ABS: do you use ABS in your Mendel?
Bed
The build plate of the 3D printer.
Belt
Toothed gear belt.
BOM
Bill of Materials. a list of parts. There are BOM for the whole Mendel and for individual components.
Carriage
The moving middle assembly on the x-axis of Mendel which holds the extruder. Often referred to as: x-carriage.
FDM
Fused Deposition Method Where a droplet of one material (plastic, wax, metal, etc.) is deposited on top or alongside the same material making a joint (by heat or adhesion).
Extrude
The act of placing the build material on the build platform. Normally by heating plastic to a liquid state and pushing it through a small nozzle.
Extruder
A group of parts which handles feeding and extruding of the build material. Consists of 2 assemblies: a cold side to pull and feed the thermoplastic from the spool, and a hot side that melts and extrudes the thermoplastic.
Filament
Two uses:
  • Plastic material made into (often 3mm) string to be used as raw material in 3D printers.
  • Extruded plastic (often <1 mm)
Heated Bed
A build surface that is warmed in order to keep the base of an extruded part from cooling (and shrinking) too quickly. Such shrinking leads to warping internal stresses in RP parts. The most common result is corners of parts lifting off the build surface. Heated beds usually yield higher quality finished builds.
Hot End
The parts of the extruder that get hot enough to melt plastic, or potentially other materials. Hot end parts use materials that can stand up to ~240 C heat (for current thermoplastic extrusion). The hot end usually refers to the tip of the extruder as it should be hottest there.
Kapton tape
Used to secure the heating element to the extruder barrel. It can also be used on the surface of a heated bed.
Nichrome
An alloy of Nickel and Chromium. Nichrome wire is used as a heating element in many extruder barrels and some heated bed designs.
NEMA
PEEK
Polyether ether ketone
Heat resisting thermoplastic used as a thermal barrier in the extruder.
PLA
Polylactic acid
A biodegradable polymer which is used as a 3D printer material.
Often PLA is used as a short form, actually referring to filament made of PLA: I use PLA in my Mendel.
PTFE
Polytetrafluoroethylene (Teflon)
A slippery thermoplastic often used as a barrel in the extruder to minimize friction with the filament.
RP
Rapid Prototyping
Creating an object in a matter of hours on a "3D printer" as opposed to sending out a job to a modelling shop that can take days or weeks.
STL
Stereo Lithographic
A file format used to describe 3D objects. A design program (e.g. AoI) can produce an STL file which can then be fed to a 3D printer or 3D rendering graphics package.
Wade's Extruder
An alternative to the standard extruder
