HackerBot BOM
Revision as of 14:23, 2 January 2014 by Balestrino (talk | contribs)
HackerBot Documentation
Structure
Structure
qty part name description/notes
13 Aluminum profile 30x30 450mm
4 Aluminum profile 30x30 600mm
26 Internal bracket (Bosch 3842535577) back plate may support upper backside profile, so four less brackets
10 Plexy support
XY System
XY System
2 Stepper motor Nema17 1.7A or 2.5A, shaft 5mm
1 Front right support plate
1 Front left support plate
1 Back right support plate
1 Back Left support plate
20 Collar nut (Bosch 3842523925) fixes the support plate with alu profiles
20 T-Bolts (Bosch 3842523920) fixes the support plate with alu profiles
32 M3x16 screw set fixes the bearing supports with support plates
8 608 Bearings
8 Bearing housing 3D printed
8 PTFE shim or POM / Delrin
8 GT2 20 teeth pulley with 8mm bore
2 GT2 20 teeth pulley with 5mm bore
4 Cubic slider
8 Cubic slider belt clamp 3D printed
8 M3x15mm for cubic slider
4 Cubic slider PTFE bushing
2 Shaft 8mm length 465mm
2 Shaft 8mm length 438mm
2 Shaft 8mm length 370mm Head shaft support
1 Head v2 assembled (4x LM8UU, Pneufit)
4 GT2 open belt length 830mm XY core belts
1 GT2 closed belt 77 teeth SDP-SI.COM (6R51M077060)
1 GT2 closed belt 66 teeth SDP-SI.COM (6R51M066060)
1 Belt Tightener with screws and 624zz bearing
1 Belt Tightener short with screws and 624zz bearing
1 X endstop holder 3D printed
1 Y endstop holder 3D printed
2 microswitch / endstop
Z System
Z System
1 Z Stepper plate
1 Z Stepper motor nema 17 1.7A
1 Z Stepper motor screw kit 4x M4x20 screws, 4x washer
4 SK10 Shaft support 10mm shaft
10 Collar nut (Bosch 3842523925) used for stepper plate and SK10
10 T-Bolts (Bosch 3842523920) used for stepper plate and SK10
1 Motor-Trapezoidal screw coupler
1 Trapezoidal screw 12x3 length 410mm
2 Z shaft 10mm length 390mm
2 LM10LUU 10mm linear bearing with housing
1 LM10LUU screw kit 8x M5x20 screw, 8x M5 washer
1 Print area support L-shaped
1 Trapezoidal nut
1 Aluminium heatbed support
4 Springs
1 Z endstop holder
1 Z endstop tuning
1 Z endstop knob
1 Z endstop spring
1 Collar nut (Bosch 3842523925) used for Z endstop holder
1 T-Bolts (Bosch 3842523920) used for Z endstop holder
1 M4 threaded rod length 60mm
1 Mechanical Z endstop
Door
Door
1 Door Plexy
2 Aluminum profile 20x20 length 408mm
2 Aluminum profile 20x20 length 384mm
4 Cubic joint 20x20 2 way Bosch 3842524484
2 Hinge Bosch 3842544526
1 Handle  ?
Electronics
Other parts
1 LCD screen XXL screen from RRD
1 Power Supply 24V Switching power supply 350W
1 Power Inlet Bulgin BVA01/Z0000/11 (RS: 352-1825)
1 RUMBA electronics
1 RAMPS electronics
1 microswitch
1 Silicon cable Black (RS: 265-3022) , Red (RS: 265-3016)
1 LIYY cabling Unitronic LIYY 4X0,25mmq (RS: 4918983)
1 LIYY cabling Unitronic LIYY 2X0.14mmq (RS: 4451395)
