HackerBot User Manual
Revision as of 09:56, 2 January 2014 by Balestrino (talk | contribs) (Created page with "{{RepRapNavigation|name=HackerBot}} ==Software== HackerBot eats STL, OBJ and AMF files. You can slice 3D parts with these free software: * [http://slic3r.org/ Slic3r] * [ht...")
HackerBot Documentation
Software
and save GCODE on the SD Card.
By the LCD menu you can control the printer and select file to be printed
Without the LCD you should connect with an USB cable an run one of these programs:
Printer Calibration
Acceleration max: 4000mm/s2
X/Y velocity max: 160mm/s
Z velocity max: 10mm/s
work area: 280mm x 280mm
maximum height: 250mm
center of the bed is at X150 Y150
http://calculator.josefprusa.cz/
Firmware upgrade
Firmware is ErikZalm Marlin
v1.3 configuration.h file can be downloaded here: ([email protected])
