HackerBot print area
Revision as of 08:32, 22 October 2015 by Balestrino (talk | contribs)
HackerBot Documentation
** SECTION INCOMPLETE OR OUTDATED **
Assembling Print area
qty | part name | description/notes |
1 | Print bed | MK* heatbed or acrylic plate |
1 | Heatbed glass | needed for MK* heatbeds |
4 | MK* Heatbed springs | 25mm length compression spring (1.2mm wire) |
4 | M3x35 heatbed | use a washer to avoid scratching the heatbed |
4 | Clamps |
First assemble and check: MK Heatbed wiring
Insert the four M3 screws in the MK Heatbed holes with a washer between head screws and hot plate.
Fasten the 4 screws in threaded holes of Heatbed support keeping a distance between this and the hot plate:
** Print area COMPLETE **
** GO TO >> HackerBot base **
