Heavy Mendel
Revision as of 11:42, 2 September 2012 by Petrus (talk | contribs)
Heavy Mendel, a self replicating 3D printer/mill/PCB engraver
Heavy Mendel concept design
The design is inspired by the triangular frame of the reprap mendel, It will be heavier and more rigid to be able to mill plastic, engrave circuit board and print at high speed. Differences compared to the standard mendel :
  • vertical X axis to quickly change the tool (extruder or spindle)
  • M10 and M12 threaded rods instead of M8 for better frame stiffness
  • 10mm smooth rods instead of 8mm for better axis stiffness
  • Precision doubling belt configuration inspired by Madkite's design : http://www.thingiverse.com/thing:8852
  • nema23 steppers for the X and Y axis instead of nema17
  • Each axis will be equipped with 4 printed linear bearings : http://www.thingiverse.com/thing:16946
Files
stl files
sketchup files
Electronics
Stepper driver
soft start
axis panel
extruder panel
probe
extruder switch
RC servo driver
Heavy Mendel RepRap discussion forum
