Huxley seedling hot end
Huxley seedling Hot-end Version 2.0
Release status: experimental
Description | designed Specificaly for the Huxley seedling.
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Introduction
I know yet another Hot End Sorry..
This one is designed Specificaly for Huxley seedling.
note: It might be possible to use wooden dowel instead of Peek for the insulator.
The requirements.
Keep it simple.
1.7 mm filament.
Bowden fillament drive.
Low profile to get best print height.
The ability to mount it in 6mm thick perspex.
Interchangable Extruder head. 0.2mmm 0.4mm 0.6mm (Fine, Normal, Draft)
Components:-
1 Thermocouple.
1 Heater block.
1 Brass Halfnut.
1 2 pin connector.
1 PCB / Veroboard.
2 E clips for fitting.
1 5W Heater resisistor.
1 3mm PTFE bowden tube 365mm.
1 Interchangable Extruder head.
1 16mm Peek insulator 20mm long.
1 Brass Threaded bar 20mm long.
Drawings
TBUL
Assembly
TBUL
Fitting
TBUL
