List of Abandoned and Deprecated Firmware
This page holds a list of all abandoned, deprecated and/or out-of-date firmware.
For firmware that is currently active and being developed, see List of Firmware
FiveD
FIRMWARE INFO | |
Details | Description |
The granddaddy of all firmwares. It appears to be the original G-code interpreter. Forked from Generation2. The reason it's called FiveD is because it controls 5 dimensions: X, Y, Z, Feedrate, and Extrusion rate. |
Features | |
Compatible Electronics | |
How to download | |
The firmware is now hosted on Github. To check it out from github, run: git clone https://github.com/reprap/firmware.git The firmware is in the FiveD_GCode Directory | |
Documentation & Misc. Notes | |
Documentation is over at Microcontroller firmware installation Preconfigured sources for Gen7 hardware are on the Gen7_Board_1.2 page. |
Hydra-MMM
FIRMWARE INFO | |
Hydra is a multi-headed manufacturing machine that was originally being designed and built for ME463 (senior design) at Purdue University. |
Features | |
How to download | |
Downloadable from sourceforge in a zip file | |
The only documentation is on the wiki under Hydra-MMM Software and Firmware |
Generation 2 firmware
FIRMWARE INFO | |
Name : Generation 2 firmware |
This appears to be an early prototype of the FiveD firmware |
Features | |
unknown | |
How to download | |
All the links for this firmware are dead. It is probably buried somewhere in the past of the reprap FiveD repository | |
Documentation appears to be at Generation2Firmware |
Gen2OnABoard
FIRMWARE INFO | |
This is an experimental fork of FiveD for the Gen2OnABoard electronics. May not actually work. |
Features | |
How to download | |
Downloadable from github by running: git clone https://github.com/reprap/firmware.git | |
Documentation is non existent |
Generation 3 firmware
FIRMWARE INFO | |
Name : Generation 3 firmware |
This appears to be a dead branch of firmware. The firmware date is 2008-08-05 |
Features | |
How to download | |
Version 1.2 appears to be the last version and it's in a zip file here. | |
The only mention of Gen3 firmware is in the wiki at Generation3Firmware
Tonokip
FIRMWARE INFO | |
Tonokip is a firmware rewrite based off of the Hydra-mmm firmware. |
Features | |
How to download | |
The real repository appears to be downloadable by running git clone https://github.com/johnnyr/Tonokip-Firmware.git HOWEVER, for some reason, it's also in a subfolder along with the FiveD firmware. So it looks like you can run git clone https://github.com/reprap/firmware.git and the firmware is in the Tonokip_Firmware Directory | |
Appears to have been forked off as Sprinter firmware. This firmware is recommended by Makergear for their Prusa Mendel kit, which runs RAMPS. |
Klimentkip
FIRMWARE INFO | |
This was originally a fork of Tonokip but is now called Sprinter |
Features | |
unknown | |
How to download | |
You can still download from Kliment's github repository by running git clone https://github.com/kliment/Klimentkip.git | |
Can't find any documentation and the firmware is officially defunct now |
Firmware build process which documents the process for Darwin hardware using the PIC 16F648 in Generation 1 Electronics.
