Lubrication
Lubrication is important aspect of every CNC machine and the RepRap is no exception. Proper lubrication will make your machine run smoothly, will suppress or even remove ugly noises and reduce wear and tear of your components. This article is a practical overview of lubricants compatible with the RepRap project, but the Wikipedia Lubrication article is a good overview of the theoretical mechanisms of lubrication.
For each lubricant, there are several factors to take into account:
- Viscosity - a thick grease might clog up your bearings, but would be fine on a threaded rod. (see NLGI Grade)
- Reactivity - will the lube soften or dissolve your plastic? Most lubricants are formulated for steel, but not all. It might also react if combined with other lubricants.
- Friction - all lubricants are designed to reduce friction, but some get closer to zero than others. Some are formulated for ultra-high speeds & heat reduction, for example.
- Maintenance - RepRap doesn't wear out lubricant anywhere near as quickly as your car, but dust and grime will accumulate in a sticky oil.
There was a recent discussion in the forums regarding lubrication. The information on this page might need to be updated. [Reprap-Compatible Grease] --Buback 22:21, 25 October 2010 (UTC) "Linear bearing compatible lubrication?".
Lubricants by application
The main parts of the RepRap machine that need to be lubricated are:
- Threaded Rod
- Bearings and bearing rails
- Bushings (if used instead of bearings)
Threaded Rod
Both Darwin and Mendel RepRap models have multiple Z-stage drives constructed using threaded rod and a captive nut, though some experimental or RepStrap machines use only one. There are RepRap clones that have X and Y also made with threaded rod and a nut. Friction between nut and threaded rod, especially under the load of the Z platform in Darwin based models is huge and if not lubricated the Z-Stage will produce ugly squeaking sounds and rub off metal powder, and soon your threaded rods will show signs of wear and tear (especially if you use a lot of Z-Motion). Properly lubricating the rods will reduce the wear and tear on the rods (not to mention reducing the ugly sounds). So far, high viscosity PTFE filled oil (super-lube for example) shown best results here.
Bearings
There are two major types of bearings found in RepRap machines.
- Roller bearings
- Linear bearings
Roll bearings
These bearings are usually closed and have their own lubrication, so no additional lubrication is needed.
Linear bearings
Linear Bearings come in open and close package. The closed ones have their own lubrication and no additional lubrication is needed while open ones need additional lubrication. high-viscosity PTFE filled oil (super-lube) for example shown best results here. Synthetic Gear Oil also shown very good results. On the other hand, TheGremlin recommends low viscosity lithium soap based lube. High viscosity greases, such as axle grease, can clog up roller bearings and cause them to slide instead of rolling. This will wreck havoc on your expensive precision ground linear rods. He recommends a grease NLGI Grade 1 or 0.
Bushings
Depending on the type of a bushing (PLA on Chrome, PTFE on Chrome, ABS on Chrome ..) you will need to find appropriate lubricant. Note that some oils do not interact well with some plastics. In most cases when using PTFE on Chrome no lubrication is needed but some PTFE filled oil will help a bit especially if you use PTFE inserts for X or Y movement. Multipurpose grease also shown nice results. Because the smooth rods are in the open air, most oils and greases will accumulate dust. Silicone based dry lube is a potential solution to this problem, according to TheGremlin's post.
Less Successful Lubricants
- WD40 is possibly the worst lubricant, tested on a Darwin based RepRap rapman. It "ate up" the Z threaded rods and produced huge amounts of ugly black gunk that was impossible to remove while not improving Z movement at all.
- Light oil reduced the squeaking sound but did not really help with friction and on the bushings it even increased friction (by attracting dust and creating sticky surface on the slider rod). CupCakeStrap has used light machine oil for the linear rails, which are aluminum rod and brass tube bushings. The oil worked very very well, but over a one-month period the oil formed some black gunk, and much of it leaked down from the rails onto the acrylic X stage, lightly discoloring it. The gunk is easily removed, but doing so dries out the rail.
- Silicone grease that is often used with RepRap is actually meant to be used with rubber gaskets, O-rings and similar equipment. It is not "bad" and some users report good results with it. There is also silicone grease with PTFE that is reported to work well.
Summary Table
Here's all the lubricants mentioned in this article, summarized in a table:
Lubricant type | Form | Viscosity | Known Reactivity | Friction | Maintenance | Sources | Other notes |
PTFE filled oil | oil/solid | ? | compatible with ABS and PLA | ? | ? | Super Lube | Good for threaded rods, bushings, and bearings |
PTFE filled grease | grease | ? | compatible with ABS and PLA | ? | ? | Super Lube | ? |
low viscosity lithium soap | grease? | NLGI Grade 1 or 0 is recommended | ? | ? | ? | May be hard to source locally | Good for linear bearings |
Silicone based dry lube | Aerosolized solid | N/A | ? | ? | Dry, so no dust problems | ? | Good for bushings |
Graphite | solid suspension in isopropanol | N/A | ? | ? | brakes down and becomes a friction agent "after a bunch of years" | Brand name "Neolube" | Can also run a soft artists pencil through threaded rod* |
PTFE based dry lube | solid | N/A | ? | ? | Needs somewhat frequent replacement (a mountain bike chain needs re-lubrication after 3-5 rides) | Sold in hardware stores. Label may say Teflon instead of PTFE. | Good for motorcycles and mountain bikes |
Synthetic Gear Oil | oil | ? | ? | ? | ? | ? | Good for linear bearings |
Multipurpose grease | grease | ? | ? | ? | ? | ? | Good for bushings |
Silicone grease | grease | ? | ? | ? | ? | ? | Meant as a sealant for rubber gaskets, O-rings, etc. |
Light oil | oil | ? | Bad for aluminium and/or brass; discolors acrylic | Doesn't reduce bushing friction much? | ? | ? | CupCakeStrap had poor results |
WD-40 | oil | ? | Reacts with metal | Doesn't reduce friction | ? | ? | Designed for eating rust, NOT lubrication |
- Most pencil cores are made of graphite mixed with a clay binder. While graphite is quite soft, clay is hard and abrasive; the OPPOSITE of the qualities we want for RepRap. Besides, graphite under 80% pure makes poor lubricant. ([[Wikipedia: Dry_lubricant#Graphite source]) Only types 5B and above meet this criteria (list of pencil compositions), so standard pencils (world HB, or US #2) are not suitable at only 68% graphite. In fact, the US system doesn't even include any high-graphyte pencils because there is no value below #1. (Wikipedia: Pencil#Grading_and_classification)
Dry lubricants are an enticing option for RepRap. It solves the dust buildup problem elegantly, and we really don't need motor oil or grease intended for power tools/industrial machines. The downside is that they don't adhere well, so they may require more frequent re-application. If applied in an AF-coating, however, they will last much longer. (see the Wikipedia page for details.) If anyone has any experience using graphite or other powdered solid lubricants, please add your knowledge!
