MKS GEN
Revision as of 02:34, 22 November 2014 by Leiochen (talk | contribs) (Basic setup)
Template:MKS GEN
Release status: Working
Single board solution, Remix of Arduino mega2560 and RAMPS1.4
Summary
We like the combination of Arduino MEGA2560 plus RAMPS1.4 and A4988 in 3D printer,and we also find some short for them.Such as we have to plus a lot,the volume is more big etc. Then we design a new PCBA which combine all major features of these open-source PCBAs:Arduino Mega 2560, RAMPS1.4. MKS GEN V1.1 has the powerful processor ATMEGA2560 WITH 256K flash memory. It use FTDI FT232R device for USB and not ATMEGA16U2 as ARDUINO MEGA2560. In power input, we use L5970D replacing the LM1117-5.0, which make MKS GEN V1.1 supporting 24V or 12V input. And XH series sockets let us easy inset the wire of step motor and end stop.
Configuring Arduino
MKS GENV1.1 is supplied with a Marlin firmware. Of course you can also upload another firmware. You can use Arduino IDE to upload firmware to MKS Base V1.0 board through ICSP PIN. While uploading the blue LED is lit and the RX/TX LEDs will blink fast.
Basic setup
This photo will show you how to connect the board. And the PIN map is in showed at below file (File:MKS GEN-PIN.PNG), you can attached other module as bluetooth, SD ramps etc.
Files
How to get it
MakerBase.com.cn
Cubic-Print.de
Maker-Base v.1.0 from US to Worldwide
