MKS GEN
Revision as of 03:39, 22 November 2014 by Leiochen (talk | contribs) (Summary)
Template:MKS GEN
Release status: Working
Single board solution, Remix of Arduino mega2560 and RAMPS1.4
Summary
MKS Gen is a feature rich all-in-one electronics solution for Reprap and other CNC devices.
It features an onboard ATmega2560. Its five motor outputs are powered by Pololu pin compatible stepper drivers.
The board features a developer friendly expansion port supporting giving access the same as Ramps1.4.
MKS Gen is designed to be flexible in the user's power source availability, allowing any power supply from 12V-24V.
Safety Tip
MKS Gen USB Driver for windows
Features
1) All functions integrate in one board, keep many interface for DIY updated.
2) Firmware can use the same configuration as ramps1.4 .
3) Fits 5 * 4988/8825 stepper driver board.
4) 4 layers PCB, optimize heat dissipation.
5) Support 12V-24V power input.
6) Can be directly connected Ramps1.4, 2004LCD control panel and 12864LCD control panel.
7) Each stepper driver slot has a breakout to connect external stepper drivers to the board.
8) Retained Servos, AUX-1, AUX-2 interface the same as Ramps1.4 .
9) Provide three 5V output, three 12V-24V output interface.
10) 4 x MOSFET drivers for hotend0,hotend1 bed and cooling fan.
11) Recoverable fuse for short-circuit protection.
Motor Driver
Smart Controller
Basic setup
How to get it
