MKS GEN
Release status: Working
Description | Single board solution, Remix of Arduino mega2560 and RAMPS1.4
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Summary
MKS Gen is a feature rich all-in-one electronics solution for Reprap and other CNC devices.
It features an onboard ATmega2560. Its five motor outputs are powered by Pololu pin compatible stepper drivers.
The board features a developer friendly expansion port supporting giving access the same as Ramps1.4.
MKS Gen is designed to be flexible in the user's power source availability, allowing any power supply from 12V-24V.
Safety Tip
MKS Gen USB Driver
MKS Gen USB Driver Chip FT232RL,you can get files from ftdichip to setup driver File:Ftdi-x86.zip.
Features
1) All functions integrate in one board, keep many interface for DIY updated.
2) Firmware can use the same configuration as ramps1.4 .
3) Fits 5 * 4988/8825 stepper driver board.
4) 4 layers PCB, optimize heat dissipation.
5) Support 12V-24V power input.
6) Can be directly connected Ramps1.4, 2004LCD control panel and 12864LCD control panel.
7) Each stepper driver slot has a breakout to connect external stepper drivers to the board.
8) Retained Servos, AUX-1, AUX-2 interface the same as Ramps1.4 .
9) Provide three 5V output, three 12V-24V output interface.
10) 4 x MOSFET drivers for hotend0,hotend1 bed and cooling fan.
11) Recoverable fuse for short-circuit protection.
