MiniRambo
Revision as of 13:05, 24 June 2015 by Tonokip (talk | contribs) (Schematic)
Mini-Rambo
Release status: Working
Smaller version of RAMBo with 4 stepper drivers.
Creative Commons Attribution-ShareAlike 3.0
RAMBo Pages: RAMBo .:. RAMBo v1.0-1.1 .:. RAMBo v1.2 .:. RAMBo Firmware .:. RAMBo Development .:. MiniRambo .:. MiniRambo Development
Summary
This board is based off RAMBo, the Arduino MEGA design, and the work of RepRap community. It has 4 stepper drivers and 4 mosfet switched outputs.
MiniRambo 1.3a main connections.
Differences from Rambo
MiniRambo has:
  • 4 stepper drivers vs. 5
  • 3 Thermistor jacks vs. 4
  • 4 total mosfets vs. 6
  • PWM control of stepper current vs. Digital Trimpot
  • Can connect RepRapDiscount LCD cables directly without an adapter board. (v1.3a+)
  • Less general purpose IO connectors than Rambo.
Powering Mini-Rambo
MiniRambo you must connect power to the Primary Power input for RAMBo to operate. The USB connection is isolated from the rest of the board and cannot be a power source.
Features
Logic
  • Arduino MEGA compatible Atmega2560 and Atmega32u2 processors are compatible with all RAMPS class firmware
  • Crystals for both usb and mcu (timing accurate to 10ppm)
Motor Drivers
  • 4 A4982 1/16th microstep motor drivers(2 connectors on Z for Prusa Mendel and other dual Z printer designs)
  • PWM Outputs for (XY), Z, E0 stepper current control instead of digital trimpot.
  • Current limit on driver IC VCC to prevent permanent latchup
  • Microstep mode configured by MCU through firmware (no jumpers needed)
  • Test points for driver control signals
  • Step and Direction pins are on their own ports for synchronous movement capability
PWM DC outputs (Extruders, Fans, Etc.)
  • 4 outputs (1 Extruder, 1 BED, 2 low power (fan,etc)
  • Low resistance mosfets for cool running
  • Indicator led for each channel
Power
  • 2 power input rails
    • Heated Bed, 15A 12-35V
    • Primary Power 10A 12-28V: Motors (5A dedicated fuse) + Extruders, Fans, & Logic (5A dedicated fuse)
  • Built in SMPS for 5V generation from Extruders + fans and logic
PCB
  • 4 layer
  • 2oz copper on all layers
  • High quality, High temperature FR4-TG130 PCB
  • Gold ENIG finishing
Schematic
https://github.com/johnnyr/Mini-Rambo/blob/master/board/Project%20Outputs%20for%20Mini-Rambo/Mini-Rambo.PDF
MiniRambo 1.3a schematic pg1. MiniRambo 1.3a schematic pg2. MiniRambo 1.3a schematic pg3.
MiniRambo 1.3a schematic pg4. MiniRambo 1.3a schematic pg4.
Fuses
MiniRambo has 3 user replaceable ATO fuses (the type found in many automotives).
  • F1 5A supplies the motors.
  • F2 5A supplies the extruder heater + fan outputs and logic.
  • F3 15A supplies the heated bed output.
Firmware
Marlin 1.0.2
fork with Thermal Runaway Protection during heatup phase
https://github.com/tonokip/Marlin/tree/1.0.2-TRP
This firmware requires a change in Configuration.h:
#define MOTHERBOARD 302
Marlin development branch
https://github.com/MarlinFirmware/Marlin/tree/Development
#define MOTHERBOARD BOARD_MINIRAMBO
USB Driver
Mini-Rambo uses the same Windows CDC driver as the RAMBo USB driver.
Troubleshooting
This is a generic troubleshooting guide. These steps may vary depending on manufacturer configuration. Contact your supplier if these steps do not help.
