MiniRambo
Revision as of 17:45, 8 September 2015 by Tonokip (talk | contribs) (REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER)
Mini-Rambo
Release status: Working
Smaller version of RAMBo with 4 stepper drivers.
Creative Commons Attribution-ShareAlike 3.0
RAMBo Pages: RAMBo .:. RAMBo v1.0-1.1 .:. RAMBo v1.2 .:. RAMBo Firmware .:. RAMBo Development .:. MiniRambo .:. MiniRambo Development
Summary
This board is based off RAMBo, the Arduino MEGA design, and the work of RepRap community. It has 4 stepper drivers and 4 mosfet switched outputs.
MiniRambo 1.3a main connections.
Version differences concerning LCD controllers
  • 1.2+
    • These versions have two 2x5 pin extension headers that are compatible with the RepRapDiscount LCD controllers.
  • 1.0-1.1
    • These earlier versions use finer pitch GPIO ports that were left off the board during manufacturing. Consequently, it would be difficult to add an LCD panel to these boards.
Differences from Rambo
MiniRambo has:
  • 4 stepper drivers vs. 5
  • 3 Thermistor jacks vs. 4
  • 4 total mosfets vs. 6
  • PWM control of stepper current vs. Digital Trimpot
  • Can connect RepRapDiscount LCD cables directly without an adapter board. (version 1.3a only)
  • Less general purpose IO connectors than Rambo.
Powering Mini-Rambo
MiniRambo you must connect power to the Primary Power input for RAMBo to operate. The USB connection is isolated from the rest of the board and cannot be a power source.
Features
Logic
  • Arduino MEGA compatible Atmega2560 and Atmega32u2 processors are compatible with all RAMPS class firmware
  • Crystals for both usb and mcu (timing accurate to 10ppm)
Motor Drivers
  • 4 A4982 1/16th microstep motor drivers(2 connectors on Z for Prusa Mendel and other dual Z printer designs)
  • PWM Outputs for (XY), Z, E0 stepper current control instead of digital trimpot.
  • Current limit on driver IC VCC to prevent permanent latchup
  • Microstep mode configured by MCU through firmware (no jumpers needed)
  • Test points for driver control signals
  • Step and Direction pins are on their own ports for synchronous movement capability
PWM DC outputs (Extruders, Fans, Etc.)
  • 4 outputs (1 Extruder, 1 BED, 2 low power (fan,etc)
  • Low resistance mosfets for cool running
  • Indicator led for each channel
Power
  • 2 power input rails
    • Heated Bed, 15A 12-35V
    • Primary Power 10A 12-28V: Motors (5A dedicated fuse) + Extruders, Fans, & Logic (5A dedicated fuse)
  • Built in SMPS for 5V generation from Extruders + fans and logic
PCB
  • 4 layer
  • 2oz copper on all layers
  • High quality, High temperature FR4-TG130 PCB
  • Gold ENIG finishing
Schematic
https://github.com/johnnyr/Mini-Rambo/blob/master/board/Project%20Outputs%20for%20Mini-Rambo/Mini-Rambo.PDF
MiniRambo 1.3a schematic pg1. MiniRambo 1.3a schematic pg2. MiniRambo 1.3a schematic pg3.
MiniRambo 1.3a schematic pg4. MiniRambo 1.3a schematic pg5.
Fuses
MiniRambo has 3 user replaceable ATO fuses (the type found in many automotives).
  • F1 5A supplies the motors.
  • F2 5A supplies the extruder heater + fan outputs and logic.
  • F3 15A supplies the heated bed output.
Firmware
Marlin 1.0.2
fork with Thermal Runaway Protection during heatup phase
https://github.com/tonokip/Marlin/tree/1.0.2-TRP
This firmware requires a change in Configuration.h:
#define MOTHERBOARD 302
Marlin development tree
https://github.com/MarlinFirmware/MarlinDev/
#define MOTHERBOARD BOARD_MINIRAMBO
Using this LCD controller requires a fix in Marlin source code. In the file "ultralcd_st7920_u8glib_rrd.h" change this line:
#pragma GCC optimize (3)
To:
#pragma GCC optimize (0)
  • Note: This fix is only for the Graphical LCD. The bug is caused by the firmware sending the data too fast over software SPI.
USB Driver
Mini-Rambo uses the same Windows CDC driver as the RAMBo USB driver.
Changelog
  • 1.3
    • change fuse holder
    • change fan Mosfet
    • silkscreen fixes
    • layout improvements
  • 1.2
    • extension headers changed to 2.54mm pitch
    • fix schematic typos
  • 1.1
    • change soft start capacitor value
    • add filter capacitors to motor outputs
Troubleshooting
This is a generic troubleshooting guide. These steps may vary depending on manufacturer configuration. Contact your supplier if these steps do not help.
