Mini Mendel Mechanical construction
Revision as of 17:37, 24 November 2011 by Glenn (talk | contribs) (+ Category:Mini-Mendel Variation)
Mendel Build Documentation
General assembly of Mendel
These pages will show you how to build the mechanical structure of Mini-Mendel, based on the RepRap Version II "Mendel". Check out the overview to get a fast introduction to Mendel's design. The Mendel assembly data sheet has been designed to provide all the procurement and assembly data you need, and can be relied upon if you prefer not to follow instructions. However, it's recommended that you do assembly in the order of the list below.
  1. Overview
  2. Mendel solid model files
  3. Procurement
  4. Preparation of materials
  5. Assembly notes
  6. Extruder
  7. X-axis
  8. Z-axis
  9. Y-axis
  10. Circuit board attachment
  11. Frame
  12. Squaring the axes
