P3Steel Bill of materials
Proteins
In RepRap jargon, a vitamin is anything that you need to make a RepRap, which a RepRap can make itself.
All parts were designed using OpenScad, they are reutilized parts from the Prusa 2 and Prusa i3 box. Font files available at:Josef Prusa's repository
STL files are available at:GitHub
Almost all the structure is made of steel so you will only need th following printed parts:
Carriage parts
Endstop holders
This part allow the attachment of the endstops to the frame. You will need 3 for a basic setup (homing axes) and 6 if you want to sense both ends of each axis. Diferent endstops can be attached to the P3Steel printer. Here we list some options.
Endstop 1 | Endstop 2 | Endstop 3 | Endstop 4 | |
Image | ||||
Files | x-end-motor-abs.stl | Thingiverse | Thingiverse | Thingiverse |
Sensor type | Mechanical | Magnetic | Magnetic | Not Specific |
Author | Josef Prusa | schlotzz | jridley | Obijuan |
X-Axis motor end
This part holds the X-Axis motor, fastens the Smooth rods of the X-Axis, holds two LM8UU bearings for the left Z-Axis smooth rod and the nut for the left Z-Axis threaded bar. Diferent X-Axis motor ends can be fitted to the P3Steel printer. Here we list some options.
X Motor End 1 | X Motor End 2 | X Motor End 3 | X Motor End 4 | |
Image | N/P | N/P | N/P | |
Files | x-end-motor-abs.stl | N/P | N/P | N/P |
Author | Josef Prusa | N/P | N/P | N/P |
Image | Part (STL) | Quantity | Commentaries |
x-end-motor-abs.stl | 1 | X end motor | |
x-end-idler-abs.stl | 1 | X end idler | |
x-carriage.stl | 1 | X carriage | |
y-belt-holder.stl | 1 | Y belt holder |
Extruder parts
biggearmod_fixed.stl | 1 | Big Gear | |
smallgearmod_fixed.stl | 1 | Small Gear | |
gregs-wade-v3-motor.stl | 1 | Extruder | |
gregs-extruder-v3-idler-mod.stl | 1 | Extruder idler |
Optional parts
Photos
Vitamins
In RepRap jargon, a vitamin (also called an "imported part" or "non-printed part") is anything that you need to make a RepRap, which a RepRap cannot itself make.
Mechanical Parts
Rods
Threaded rods
Only 2 M5 threaded rods are needed:
- 2x Threaded rod M5x295 mm
Smooth rods
6 Smooth rods are needed of the following sizes:
- 2x Ø8x375 mm for X-Axis
- 2x Ø8x341 mm for Y-Axis
- 2x Ø8x320 mm for Z-Axis
Electronics
Image | Part | Quantity | Unit price | Total cost | Commentaries |
Arduino Mega 2560 board (or compatible) | 1 | -- | -- | The printer's "brain". | |
RAMPS 1.4 board | 1 | -- | -- | Interface betwen the arduino board and the hardware. | |
Stepper motor drivers. | 4 | -- | -- | Drive the motors | |
Mechanical endstops. | 3 | -- | -- | Tell the software when the carriage has reached the home position. Can be replaced with optical or magnetic sensors. | |
Smart LCD | 1(Optional) | -- | -- | Run your RAMPS without a computer just with a SD card and Gcode files. | |
Power supply. | 1 | -- | -- | Min power 16A, Recommended 30A |
