RBS
Revision as of 22:57, 10 November 2009 by Sebastien Bailard (talk | contribs) (TriLap/Building System moved to RBS: RBS is a good short name.)
Action Items
- Ask Forrest to make 2 gears which mesh, and are both bolted to a perforated sheet of metal.
- Make a 20 feet of wood gridbeam using the CNC router at architecture, maybe.
- TriLap will be a steel square-tube CNC router made with tri-lapping joints, aka Tri-Joints with Image:NEED-trijoint example.jpg Note that this is slightly similar to LumenLab's RogR, but will be cross-fertile with RepRap.
We can if we want try to extend this use of gridbeam and erector-set like technology into a TriLap/Building_System system that levrages RepRap to make lots of mechatronic systems using grid beam and grid sheet, and 3D printed gears, etc., but that's sort of beyond the scope of this project. (Step 2, technically)
