RUG/Pennsylvania/State College/Printers/PSU Blue and White
Introduction
This is the page for the State College Rep Rap User Group's (SCRUG) Blue & White 3D printer. The printer was developed, assembled, and is currently operated by students in Penn State's Engineering Design 497J course and members of the 3D printing club. Our goal is to continuously tweak the printer until it is ready for distribution and sale to other departments in the University and local schools and businesses.
This printer is mainly comprised of blue and white frame pieces.
Current Team
Lee Schwartz, Tony Armlin, Todd Troutman, Yuan Chai, Graham Deever
Log
Date | Status |
12/05/2013 | Updated wiki page to show current status. Printer has all components added and is awaiting testing and callibration. |
11/14/2013 | Printer is awaiting electronics. All other components are finished. |
11/7/2013 | Printer X-axis is completely assembled. |
8/29/2013 | Blue and White build is continued. Just the frame built. |
Spring 2013 | Blue and White build is started. |
2/18/2014 | Blue and White rejoin repair, extruder assembled, wires reconnected, limit switches adjusted. |
2/20/2014 | The distance between 2 Y-axis was adjusted, replaced the right connection part at bottom. |
2/25/2014 | Reconnected the right Z-axis, adjusted the plate, movement correct, extruding testing. |
2/27/2014 | Blue and White started work, filament entrance bolt tightened, extruding motor's gear replacing. |
4/29/2014 | The blue and white printer is currently working but could be printing better. The y-axis is off and results in elongated prints. The printer in general requires more calibration. The extruder tip also leaks melted plastic near the top of it while printing. It is still currently unknown why the extruder is leaking and where exactly the fracture or gap in the extruder is located. |
Gallery
About this printer
This printer is designed to be an Open Hybrid Mendel, or OHM for short. It is finished and as of last class needs to be tested and calibrated.
Builders
Assembled by' | |||||||||||
Leo Funk | |||||||||||
Oyenola Adeola Ogunro | |||||||||||
Justin Frazier | |||||||||||
Dimitar Dimitrov | |||||||||||
Current Operators | |||||||||||
Tony Armlin | |||||||||||
Lee Schwartz | |||||||||||
Graham Deever | |||||||||||
Yuan Chai | |||||||||||
Todd Troutman
