RUG/Pennsylvania/State College/Printers/PSU Unit Mondo
On this page you will find the current status of the Unit M Mondo. Our Mendel Unit is a Techzone laser-cut Mondo. So far, we have replaced the extruder (11/8/12) since the Techzone wooden extruder used springs to tension the idler. The new extruder improves this by using two bolts to tighten the idler. Update: (11/29/12) optical endstops were replaced with mechanical endstops and firmware was upgraded. Eventually the plan is to use this large unit with a dual extruder. Much more information can be found at RUG/Pennsylvania/State_College/Dual_Extruder
Slic3r Configuration File
Here is our current configuration file for the PSU Mondo: File:Mondo.ini.txt
Operating Specifications
Operating Specifications | |||||||
Name | Status | Design | Electronics | Firmware | Extruder | Temperature | Comments |
Mondo | Working | Mondo | Ramps V1.4 | Marlin | Joe/Kevin/Wade/Greg extruder | 210C | Running |
Build Status
What has been done: Frame assembly, Electronics installation, Replaced Thermistor with Thermocouple, Adjusted Steps/mm, Adjusted BOD rate to in Marlin to 115200, Tuning of Motor steps/mm.
Mostly up and Working, small adjustments may be needed.
What needs to be done: Fine tuning of Slic3r settings (Current Slic3r configuration file coming soon). Some motor belt adjustment may be required. Exact bed size to be determined.
