RUG/Pennsylvania/State College/Printers/PSU Unit Mondo
Revision as of 18:12, 11 December 2012 by Wjf5042 (talk | contribs)
On this page you will find the current status of the Unit M Mondo. Our Mendel Unit is a Techzone laser-cut Mondo. So far, we have replaced the extruder (11/8/12) since the Techzone wooden extruder used springs to tension the idler. The new extruder improves this by using two bolts to tighten the idler. Update: (11/29/12) optical endstops were replaced with mechanical endstops and firmware was upgraded. An overhead filament holder was added to keep the filament from tangling on the table. Eventually the plan is to use this large unit with a dual extruder. Much more information can be found at RUG/Pennsylvania/State_College/Dual_Extruder
Slic3r Configuration File
Here is our current configuration file for the PSU Mondo: File:Mondoconfig.txt
Spring 2012
Operating Specifications
Name Status Design Electronics Firmware Extruder Temperature Comments
Mondo Mondo Working Mondo Ramps V1.4 Marlin Joe/Kevin/Wade/Greg extruder 207C Running
Build Status
What has been done: Frame assembly, Electronics installation, Replaced Thermistor with Thermocouple, Adjusted Steps/mm, Adjusted BOD rate to in Marlin to 115200, Tuning of Motor steps/mm, Installed new Extruder, Replaced optical endstops with mechanical, installed overhead filament holder.
Mostly up and Working, small adjustments may be needed.
What needs to be done: Fine tuning of Slic3r settings (Mondo Slic3r configuration file is on the new HP computer in the corner). Some motor belt adjustment may be required. Exact bed size to be determined.
State College RepRap Users Group
S.C.R.U.G. Main · The Make Space · Intercollegiate Future Society · Wiki Help
