RUG/Pennsylvania/State College/Software
RepSnapper
We currently use Repsnapper Zero for printing with our robots. For more information on how to use RepSnapper, there is a basic tutorial up on the official Penn State RepRap YouTube channel that you should check out.
Skeinforge
Skeinforge is a collection of python scripts that is used to generate Gcode for the printers. Custom plugins can be added to Skeinforge to allow more functionality. To learn more see Installing Skeinforge Plugins.
Pronterface
Pronterface is a program that is used mostly for connecting to a printer and running diagnostics with it.
More details can be found here.
A ready-to-use build can be found here.
CAD
This page is for documentation of all projects, issues, and fixes regarding the design and modeling portion of RepRap.
How to upload .stl files into SolidWorks.
1. Save .stl file on computer
2. In SolidWorks click on Open File
3. Click on 'Options' button
4. Select to import as Solid Body
5. Choose correct Units
6. Check to Import texture information
7. Click on Okay and Open
You have successfully opened a .stl file into SolidWorks.
Miscellaneous Downloads
File:EMFApr29profiles.rar | Skeinforge Profiles |
File:EMFApr29alterations.rar | Skeinforge Alterations |
File:Fix.rar | AWK Script for fixing Skeinforge |
File:EMFapr29awk.rar | Happy Valley AWK Directory |
File:FirmwareforOneWireAD heatbed brnrd 20110317.zip | documented here |
File:Emf Bestextruder4 07.rar | A copy of the extruder code we have been using with max endstops enabled. |
File:Psu Bestmobocode2 24 2011.rar | TZ Gen3 Mobo code altered for our machines |
File:Extruder class jpj12 2011-04-07 temp fix.pde | Modified version of Bestextruder4_07 with brnrd's fix for temp overflow bug. DOES NOT WORK |
File:SC Skeinforge Mar24.rar | Skeinforge Settings as of March 24 |
Parts
Useful Items | Links to useful Thingiverse things. |
Demo Models | Complex models that can be used for conventions (or test your mad printing skillz). |
Hybrid Parts | OHM Parts List & STL Links |
Pen Plotter | Pen Plotter Info |
Spool Arm | Spool Arm Info |
Dual Extruder | Dual Extruder Info |
Z Opto Holder | New Z Opto Holder |
File:TEDxCard1.stl | Larger TEDx Logo STL file |
File:TEDxCard2.stl | 75% smaller TEDx Logo STL file |
