RUG/Pennsylvania/State College/Soldering
Revision as of 11:20, 10 December 2012 by Dwj131 (talk | contribs)
Never Soldered Before?
Check these out:
Sparkfun's Video Tutorial
Good walk though with pictures
Repraps soldering tutorial
How to Avoid Cold Solder Joints
When soldering, it is very easy to create joints that are "cold." A cold joint is one where the solder has only mechanically joined to one of the two pieces that you are trying to connect. The most common cause of cold solder joints is improper soldering technique. Many people simply add solder to the iron, then transfer that blog of solder from the iron to the lead sticking out of the board. This is not correct. To correctly solder, place the iron at the the intersection of the lead and the pad. Wait 1-3 seconds for the joint to heat up THEN add a small amount of solder ensuring that it flows evenly around the entire joint. A correct joint will look like a volcano.
Be Careful
Alt text
Backwards...
Alt text
Cold!
Alt text
"Dynamic" Contact
Alt text
Good joint
Alt text
Another cold joint (left)
