SugarSnap
Revision as of 13:56, 14 December 2014 by Traumflug (talk | contribs) (Fix development template.)
SugarSnap
Release status: experimental
Snap together Mendel-like with minimal vitamins
GPL
Development, Mendel Variations
OpenSCAD
SugarSnap is a Mendel-like printer, inspired by Prusa, Snapdragon and VikOlliver's nutless Mendel.
Major design goals are:
  • Minimal vitamins
  • Simple assembly
  • Small build platform printability
Specifications
  • Build Area - SugarSnap is designed to hold a Prusa Heated Bed but could hold one a bit larger so lets say 225x225x200.
  • Size - External will be about 340x340x325
  • Weight
    • Printed Parts
    • Full Assembly
Calibration and Printing
Print and test calibration pieces
Because SugarSnap is a snap together design, getting the dovetail and rod hole interfaces just right is very important. To help you do this there are three test parts to build.
dt_test.scad
This will test the dovetail interfaces. Print the plate and label the 4 pieces 950, 925, 900, 875 in order left to right, top to bottom. See which set of male dovetails fit best into the other pieces. You want a strong, tight bond, but not one that is impossible to get together.
Change the line in Libs.scad
module dovetail (width=9, height=10, male=true, fit = 0.900)
to
module dovetail (width=9, height=10, male=true, fit = 0.your fit number)
bv_test.scad
This tests the slots used in the vertices and a few other places. Print the plate and do a test fit. You want a strong, tight bond, but not one that is impossible to get together or remove.
The interface numbers are, from left to right: 0.15, 0.30, 0.45, 0.60, 0.75.
Change the line in ss_parms.scad
slot_tolerence = 0.45; // tolerence for slot connectors
to
slot_tolerence = you fit number; // tolerence for slot connectors
rod_test.stl
This tests the rod supports. Print the plate and do a test fit with your smooth rod. You want a strong, tight bond, but not one that is impossible to get together or remove.
The interface numbers are, from left to right: 0.15, 0.30, 0.45, 0.60.
rod_tol = 0.15; // tolerance added to rod holes for shrinkage
to
rod_tol = you fit number; // tolerance added to rod holes for shrinkage
Generating STLs
Create the plates...
Printing
Print the plates...
Part List
Printable Parts
  • Parts List
  • Plate Lists
    • Small Plates
    • Large Plates
Vitamins
  • Rods
  • Bearings
  • Belts
  • Motors
  • Electronics
Assembly Instructions
  • Frame
  • Motors
