Talk:Gen7 Board 1.4.1
Hi Traumflug!
Great work you did on the Gen7! Nice documentation too! I am at the moment working on building a RepRap with some friends using your new electronic design.
Browsing through this page I realized that there's probably a small mistake in the Pinout of the AVR ATmega. As far as I understand, the endstops are switches (or opto-sensors) and so they should be digital inputs to the microcontroller, no? So if that's true, then I guess pins PB0, PB1 and PB2 should be inputs not outputs. Maybe you want to double-check that.
Keep up the good work! I like the modular design. If I find the time, I might start working on a shield for a second extruder or I might try to design a through-hole one-sided Pololu-compatible plugin replacement, if I can find an adequate DIP-packaged stepper driver/controller.
