circuit board spacer m4
circuitboard bracket m3_diag
frame vertex_diag
180 z bearing plate_diag
x 360 z bearing plate mirror_diag
x 360 z bearing plate_diag
x axis side plate nut jig_diag
x bar clamp m3_diag
x bar clamp m4_diag
x caple clamp_diag
x carriage belt clamp_diag
x carriage lower_diag
x carriage upper_diag
x end bracket_diag
x motor bracket spacer_diag
x vert drive nut trap_diag
x vert drive side plate 180 end_diag
x vert drive side plate 360 end_diag
xlr bracket_diag
y bar clamp_diag
y bearing 180 inner_diag
y bearing 180 outer left_diag
y bearing 180 outer right_diag
y bearing 360 inner_diag
y bearing 360 outer left_diag
y bearing 360 outer right_diag
y belt clamp_diag
y idler bracket_diag
y motor bracket_diag
z bar clamp_diag
z drive pulley rim_diag
z leadscrew base bar clamp_diag
z leadscrew base_diag
z motor bracket_diag
z opto bracket_diag
z tensioner_diag
