ZemcikO spool holder
Revision as of 12:22, 2 August 2012 by Zemciko (talk | contribs)
This is my simple material spool holder.
Alibre 3D, STL
Simple spool holder for Mendel or any other reprap printer
Status: fully working.
Description: Its realy simple materiál spool holder. Some parts were taken from my mendel/sinuhed model. Size of threaded rods is increased. This ensures the material position obove 3d printer. Width of holder is twice as big as needed for 300mm spool. This is done to make possible design axis for 600mm spools or universal axis.
Bill of materials
Spool holder
5x M8x300mm
4x M8x480mm
2x M8x513mm (max 5Euro all rods)
47x M8 washer
25x M8 Nut
24x M8 Nylock (+- 2Euro all nuts and washers)
2x ball bearing 608zz (1Euro)
10x ABS parts (4-5 Euro for material)
300mm spool (u have one if u buy material from grrf, etc)
Total +- 12 Euro
Brake
1x M8x300mm
18x M8 Nut
10x M8 washer
20cm of "tube isolation"
9x plastic parts
another +-3 euros
Some of nylock nuts (except 4 holding bearings) can be replaced with regular M8 nusts.
Aditional improvements
Brake To prevent extra rotation of spool i have designed simple brake. It can by simple mount on spool holder and adjusted for chosen spool.
Leading for material
On top of reprap im using simple leading from plastic parts and M8 rods. Any type of "leading" can be used ill show here mine from mendel and sinuhed.
Models and drawings
Spool holder
File:STLspool.zip STL files of printed parts of ZemcikO spool holder.
File:STPspool.zip Step files of ZemcikO spool holder.
File:ZOspool.zip Alibre files of ZemcikO spool holder.
Brake
Material support (leading)
3D model and photo of working holder
TODO
Another axis for different spools.
