RAMPSXB
Revision as of 00:56, 24 August 2017 by SZiv (talk | contribs) (Bill of Materials)
RAMPSXB
Release status: Working
RAMPS eXpansion Board
Summary
RAMPSXB (RAMPS eXpansion Board) is a shield that attaches to the AUX pins of the common 3D printer control board, RAMPS.
It adds 4 additional stepper motor driver carriers, 4 additional thermistors, 4 additional PWM-controlled MOSFETs, EXP1 and EXP2 for an LCD controller (such as the RepRapDiscount Smart Controller), additional VCC pins, 5V pins, regulated TX/RX for an HC-05 chip, and suppression capacitors on the minimum endstops, similar to the RAMPS 1.4.2.
This allows for a variety of combinations, including 6 completely separate extruders, or a mixing extruder and a few fans, or a mixture of voltages (12V on the main RAMPS, and 24V on the RAMPSXB).
RAMPSXB consumes the maximum endstops, as well as servo pins 2, 3, and 4 to drive the FETs.
Open Source Files
EAGLE files can be found here: https://github.com/SZiv/RAMPSXB
Where to get it?
No manufacturers for this yet. ¯\_(ツ)_/¯ Nothing is too hard to solder, so if you can get ahold of the board, its not very hard to assemble.
Pin Definitions
E2 Direction - 15
E2 Step - 19
E2 Enable - 63
E3 Direction - 2
E3 Step - 39
E3 Enable - 58
E4 Direction - 42
E4 Step - 44
E4 Enable - 49
E5 Direction - 32
E5 Step - 47
E5 Enable - 57
Thermistor T3 - A11
Thermistor T4 - A12
Thermistor T5 - A10
Thermistor T6 - A5
MOSFET H3 - 4
MOSFET H4 - 5
MOSFET H5 - 6
MOSFET H6 - 45
Bill of Materials
Description Quantity Package Notes
Electrolytic Capacitors, 100uF, SMD 4 0605 For Stepper Carriers
Electrolytic Capacitors, 10uF, SMD 4 0405 For Thermistors
Nonpolarized Capacitor, 0.47uF, SMD 3 0805 Suppression Caps for Endstops
Resistors, SMD, 100k Ohm 8 0805 For FETS and Pulldowns
Resistors, SMD, 10k Ohm 4 0805 Pullup Resistors
Resistors, SMD, 10 Ohm 4 0805 For FETs
Resistors, SMD, 1.8k Ohm 4 0805 LED current limiting resistors
Resistors, SMD, 4.7k Ohm 4 0805 For Thermistors
Resistor, SMD, 3.3k Ohm 1 0805 Half of a Voltage divider for the HC-05 Chip. No HC-05? You don't need this!
Resistor, SMD, 2.2k Ohm 1 0805 Other Half of a Voltage divider for the HC-05 Chip. No HC-05? You don't need this!
MOSFET, Through-hole, stp55nf06l 4 TO-220 Main Power MOSFETs.
TO-220 Heatsinks 4 TO-220 Heatsinks for the FETs. Not required, but dirt cheap and suggested.
LEDs, SMD 4 0805 LEDs that tell you if the FETs are on.
Screw Terminals 5 3.5mm Input/output power terminals. If you need more than 4A, solder directly to the bottom traces.
PTC Fuses 1 N/A 30V, 9A if you cover the bottom traces for extra power, 6A if you dont.
Male/Female Pin Headers A lot? ¯\_(ツ)_/¯ 0.1" spacing. Buy a couple of Female double rows, male double rows, male single rows, and female single rows.
PCB 1 N/A The Actual PCB. I get mine from OSHPark, but you can get it from SEEED for better prices.
