RAMPSXB
Release status: Working
Description | RAMPS eXpansion Board
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Summary
RAMPSXB (RAMPS eXpansion Board) is a shield that attaches to the AUX pins of the common 3D printer control board, RAMPS.
It adds 4 additional stepper motor driver carriers, 4 additional thermistors, 4 additional PWM-controlled MOSFETs, EXP1 and EXP2 for an LCD controller (such as the RepRapDiscount Smart Controller), additional VCC pins, 5V pins, regulated TX/RX for an HC-05 chip, and suppression capacitors on the minimum endstops, similar to the RAMPS 1.4.2.
This allows for a variety of combinations, including 6 completely separate extruders, or a mixing extruder and a few fans, or a mixture of voltages (12V on the main RAMPS, and 24V on the RAMPSXB). It was originally designed to run either the E3D Kraken or Diamond Hotend, with some spare heaters for fans, lights or support extruders.
RAMPSXB consumes the maximum endstops, as well as servo pins 2, 3, and 4 to drive the FETs.
Open Source Files
EAGLE files can be found here: https://github.com/SZiv/RAMPSXB
Where to get it?
No manufacturers for this yet. ¯\_(ツ)_/¯ Nothing is too hard to solder, so if you can get ahold of the board, its not very hard to assemble.
Pin Definitions
E2 Direction - 15
E2 Step - 19
E2 Enable - 63
E3 Direction - 2
E3 Step - 39
E3 Enable - 58
E4 Direction - 42
E4 Step - 44
E4 Enable - 49
E5 Direction - 32
E5 Step - 47
E5 Enable - 57
Thermistor T3 - A11
Thermistor T4 - A12
Thermistor T5 - A10
Thermistor T6 - A5
MOSFET H3 - 4
MOSFET H4 - 5
MOSFET H5 - 6
MOSFET H6 - 45
Bill of Materials
Description | Quantity | Package | Notes |
Electrolytic Capacitors, 100uF, SMD | 4 | 0605 | For Stepper Carriers |
Electrolytic Capacitors, 10uF, SMD | 4 | 0405 | For Thermistors |
Nonpolarized Capacitor, 0.47uF, SMD | 3 | 0805 | Suppression Caps for Endstops |
Resistors, SMD, 100k Ohm | 8 | 0805 | For FETS and Pulldowns |
Resistors, SMD, 10k Ohm | 4 | 0805 | Pullup Resistors |
Resistors, SMD, 10 Ohm | 4 | 0805 | For FETs |
Resistors, SMD, 1.8k Ohm | 4 | 0805 | LED current limiting resistors |
Resistors, SMD, 4.7k Ohm | 4 | 0805 | For Thermistors |
Resistor, SMD, 3.3k Ohm | 1 | 0805 | Half of a Voltage divider for the HC-05 Chip. No HC-05? You don't need this! |
Resistor, SMD, 2.2k Ohm | 1 | 0805 | Other Half of a Voltage divider for the HC-05 Chip. No HC-05? You don't need this! |
MOSFET, Through-hole, stp55nf06l | 4 | TO-220 | Main Power MOSFETs. |
TO-220 Heatsinks | 4 | TO-220 | Heatsinks for the FETs. Not required, but dirt cheap and suggested. |
LEDs, SMD | 4 | 0805 | LEDs that tell you if the FETs are on. |
Screw Terminals | 5 | 3.5mm | Input/output power terminals. If you need more than 4A, solder directly to the bottom traces. |
PTC Fuses | 1 | N/A | 30V, 9A if you cover the bottom traces for extra power, 6A if you dont. |
Male/Female Pin Headers | A lot? ¯\_(ツ)_/¯ | 0.1" spacing. | Buy a couple of Female double rows, male double rows, male single rows, and female single rows. |
PCB | 1 | N/A | The Actual PCB. I get mine from OSHPark, but you can get it from SEEED for better prices. |
