Template:Firmware Support/ua
< Template:Firmware Support
Revision as of 06:55, 6 April 2023 by Edlab (talk | contribs)
Support Marlin RepRapFirmware Klipper Prusa Buddy Repetier Smoothie Druid MK4duo
grbl Sprinter BFB FiveD Machinekit Redeem Teacup Yaskawa MakerBot
How to use
Copy one of the examples below as a starting-point, paste it into the G-code wiki page above your G-code description, and edit as needed. You can put anything as a value, but certain values will be color-coded for easier reference. The following embed…
{{Firmware Support | marlin={{yes}} | reprapfirmware={{yes|3.4+}} | klipper={{yes}} | prusa={{yes}} | buddy={{yes}} | repetier={{partial}} | smoothie={{yes}} | druid={{automatic}} | mk4duo={{yes}} | grbl={{no}} | sprinter={{yes}} | bfb={{no}} | fived={{yes|1.23+}} | machinekit={{experimental}} | redeem={{yes}} | teacup={{???}} | yaskawa={{yes}} | makerbot={{no}} }}
…will produce this result:
Yes 3.4+ Yes Yes Yes Partial Yes Automatic Yes
No Yes No 1.23+ Experimental Yes ??? Yes No
Special Values
Value Description
??? Unknown if the firmware supports this G-code. Try to find out before posting. This is the default if a firmware is left out.
yes The G-code is fully supported by the firmware.
yes|1.23+ The G-code is supported by version 1.23 and above.
no The firmware does not support the G-code at all.
partial There is only partial support for the full G-code specification.
experimental The G-code is experimental and may change or be removed.
automatic The firmware handles this G-code automatically. (Unclear, so avoid this label.)
Examples
Unknown
{{Firmware Support | marlin={{???}} | reprapfirmware={{???}} | klipper={{???}} | prusa={{???}} | buddy={{???}} | repetier={{???}} | smoothie={{???}} | druid={{???}} | mk4duo={{???}} | makerbot={{???}} | grbl={{???}} | sprinter={{???}} | bfb={{???}} | fived={{???}} | machinekit={{???}} | | redeem={{???}} | teacup={{???}} | yaskawa={{???}} }}
- or simply -
{{Firmware Support}}
None
For completely new G-codes this is probably the best starting-point.
{{Firmware Support | marlin={{no}} | reprapfirmware={{no}} | klipper={{no}} | prusa={{no}} | buddy={{no}} | repetier={{no}} | smoothie={{no}} | druid={{no}} | mk4duo={{no}} | makerbot={{no}} | grbl={{no}} | sprinter={{no}} | bfb={{no}} | fived={{no}} | machinekit={{no}} | | redeem={{no}} | teacup={{no}} | yaskawa={{no}} }}
No No No No No No No No No
Marlin Derivatives
This may be an easier starting-point for Marlin derivatives that support similar G-codes.
{{Firmware Support | marlin={{yes}} | reprapfirmware={{???}} | klipper={{yes}} | prusa={{yes}} | buddy={{yes}} | repetier={{???}} | smoothie={{???}} | druid={{yes}} | mk4duo={{yes}} | makerbot={{???}} | grbl={{???}} | sprinter={{???}} | bfb={{???}} | fived={{???}} | machinekit={{???}} | | redeem={{???}} | teacup={{???}} | yaskawa={{???}} }}
- or simply -
{{Firmware Support | marlin={{yes}} | klipper={{yes}} | prusa={{yes}} | buddy={{yes}} | druid={{yes}} | mk4duo={{yes}} }}
Yes ??? Yes Yes Yes ??? ??? Yes Yes
Adding a Title
You can override the default title that appears on the left side ("Support") using title=Something Else. For example:
{{Firmware Support | title=M123<br>Support | marlin={{no}} | reprapfirmware={{no}} | klipper={{no}} | prusa={{no}} | buddy={{no}} | repetier={{no}} | smoothie={{no}} | druid={{no}} | mk4duo={{no}} | makerbot={{no}} | grbl={{no}} | sprinter={{no}} | bfb={{no}} | fived={{no}} | machinekit={{no}} | | redeem={{no}} | teacup={{no}} | yaskawa={{no}} }}
M123
Support
