GUS Simpson
From RepRapWiki
GUS Simpson Documentation
Main page | GUS Simpson Buyer's Guide | GUS Simpson Build Manual | GUS Simpson User Manual | GUS Simpson improvements | GUS Simpson electronics and calibration
GUS Simpson
Release status: experimental
Description Grounded Delta Printer
License GPL
Author Nicholas.seward
Based-on [[RepRap Morgan, Rostock, Delta]]
CAD Models Github
External Link ConceptForge.org
GUS Simpson is a experimental grounded delta robot 3D printer prototype, built in 2013 by Nicholas Seward in Hot Springs, Arkansas, USA. Simpson is named after George Gaylord Simpson who came up with the idea of Quantum Evolution, the theory that evolution can happen in abrupt burst. The name signifies that this is a quick divergence (idea to first print in 1 month) from other existing designs.
Design Goals
Specifications
Videos
Firmware
While reportedly in the works, there is currently no firmware which allows the GUS Simpson to appear like a standard cartesian 3D printer. Thus, you cannot just send it gcode directly from your slicer and expect anything other than utter havoc.
Printing is currently achieved using any vanilla firmware which can directly control X, Y, and Z steppers, using a gcode preprocessor to transform the cartesian gcode commands into something that makes sense for the delta configuration of the GUS Simpson. With this method, it makes no difference which firmware you use (Repetier is used by the original author). If you do this, make sure you don't forget to always use the gcode preprocessor or bad things will happen!
Software
Homing
RepRapNess
At this point the GUS Simpson cannot produce the dimensionally accurate parts required for self replication.
Future Developments
Links
1. RepRap Forum Development thread: Grounded Experimental Delta Printer
2. Nicholas Seward's Youtube Channel
3. Github Repository
4. ConceptFORGE forums
