Integrated Voltage—Current Monitoring and Control of Gas Metal Arc Weld Magnetic Ball-Jointed Open Source 3-D Printer
By Michigan Tech's Open Sustainability Technology Lab.
Wanted: Students to make a distributed future with solar-powered open-source RepRap 3-D printing and recyclebot recycling. |
This page is part of an international project hosted by MOST to use RepRap 3-D printing to make OSAT for sustainable development. Learn more.
Research: Open source 3-D printing of OSAT • RecycleBot • LCA of home recycling • Green Distributed Recycling • Ethical Filament • LCA of distributed manufacturing • RepRap LCA Energy and CO2 • Solar-powered RepRaps • solar powered recyclebot • Feasibility hub • Mechanical testing • Lessons learned • MOST RepRap Build Make me: Want to build a MOST RepRap? - Start here! • Delta Build Overview:MOST • Athena Build Overview • MOST metal 3-D printer • Humanitarian Crisis Response 3-D Printer |
Source
- Integrated Voltage—Current Monitoring and Control of Gas Metal Arc Weld Magnetic Ball-Jointed Open Source 3-D Printer
- Franklin firmware
- Yuenyong Nilsiam, Amberlee Haselhuhn, Bas Wijnen, Paul Sanders, & Joshua M. Pearce. Integrated Voltage - Current Monitoring and Control of Gas Metal Arc Weld Magnetic Ball-Jointed Open Source 3-D Printer.Machines 3(4), 339-351 (2015). doi:10.3390/machines3040339 open access
- Full hardware source available at: https://osf.io/ytvgm/ (includes CADs, BOM and STls)
- Full source code for voltage and current data processing available at: MOST-Voltage-Current-Data-Processor (*.m for MATLAB or Octave)
- 3D Metal Printing Slicer Plugin
Abstract
To provide process optimization of metal fabricating self-replicating rapid prototyper (RepRap) 3-D printers requires a low-cost sensor and data logger system to measure current (I) and voltage (V) of the gas metal arc welders (GMAW). This paper builds on previous open-source hardware development to provide a real-time measurement of welder I-V where the measuring circuit is connected to two analog inputs of the Arduino that is used to control the 3-D printer itself. Franklin firmware accessed through a web interface that is used to control the printer allows storing the measured values and downloading those stored readings to the user’s computer. To test this custom current and voltage monitoring device this study reports on its use on an upgraded all metal RepRap during the printing of aluminum alloy (ER1100, ER4043, ER4943, ER4047, and ER5356). The voltage and current data were analyzed on a per alloy basis and also layer-by-layer in order to evaluate the device’s efficacy as a monitoring device for 3-D printing and the results of the integrated design are discussed.
Keywords
3-D printing, gas metal arc weld, GMAW, metal inert gas welding, MIG welding, power monitoring, additive manufacturing;data logging; metal printing;open-source hardware; quality control;RepRap; welder;welding
See also
- [[Open-source metal 3-D printer [1]]]
- [[Low-cost Open-Source Voltage and Current Monitor for Gas Metal Arc Weld 3-D Printing[2]]]
- [[MOST open-source metal 3-D printer v2[3]]]
- [[Substrate Release Mechanisms for Gas Metal Arc Weld 3D Aluminum Metal Printing[4]]] - how to get your print off the substrate with a hammer
- [[In Situ Formation of Substrate Release Mechanisms for Gas Metal Arc Weld Metal 3-D Printing[5]]]
- [[Aluminum substrate cleaning for 3-D printing:MOST[6]]]
- [[Hypoeutectic Aluminum–Silicon Alloy Development for GMAW-Based 3-D Printing Using Wedge Castings[7]]]
- [[Open-source Lab[8]]]
- [[Open source 3-D printing of OSAT[9]]]
- [[Life-cycle economic analysis of distributed manufacturing with open-source 3-D printers[10] ]]
- [[Environmental impacts of distributed manufacturing from 3-D printing of polymer components and products[11] ]]
- [[Building research equipment with free, open-source hardware[12] ]]
- Delft University of Technology - MIG+ Prusa I3[http://www.appropedia.org/Integrated_Voltage%E2%80%94Current_Monitoring_and_Control_of_Gas_Metal_Arc_Weld_Magnetic_Ball-Jointed_Open_Source_3-D_Printer]
- Weld 3D - 1st commercial spin off
- see literature on "wire arc additive manufacturing" (WAAM)
