I'm new to RepRaps and I'm curious about the costs
October 20, 2011 06:29PM
I'm looking for some advice on what I should buy, how much should I spend, and what mods are recommended for my needs.
I need a machine that can make pieces 8" x 8" x 3" in size out of durable ABS. I'm thinking about a Prusa Mendel, but I would like to keep in within a $600 budget.
Do the ladies and gentlemen of the RepRap world have a preferred beginner unit that a novice can throw together and build on?
Re: I'm new to RepRaps and I'm curious about the costs
October 20, 2011 06:53PM
A Prusa is about as basic as it gets and a great place to start. But as seeing you want to build large ABS parts I would recommend building a box around it as to keep in the heat (ABS tends to warp even on a heated bed when the object is large). As for the budget I would say a Prusa is about your only choice with that large of build area in kit form.
October 21, 2011 09:57AM
Thanks for the advice on using a box with the heatbed. I should have some gold heat shielding material left over that I can use on the inside of the box to reflect the heat inward.
I'm thinking about this unit with the 3mm hot-end. Anyone have an opinion on it?
[www.makergear.com]
October 21, 2011 10:58AM
errantvandal - you can stop by the MakerGear IRC channel and chat with people about their Prusa Kits.
Rick
October 21, 2011 01:54PM
I have never dealt with Makergear but from what I have read on the forums and through peoples personal blogs I would say they are one of the best RepRap companies out there ( I have never read a single bad thing about them).
October 21, 2011 02:21PM
@sublime also check out [reprapbook.appspot.com]
