All,
I'm getting ready to put the connectors on my Kysan stepper motors so I can connect them to my ramps and give them a test.
Seems like every motor brand and model has different wires and colors, so I'm just looking for a quick sanity check before I flip the switch and test these. Not sure if hooking them up incorrectly would cause any damage to the stepper drivers or not, so I figured I'd ask here first.
I have some Kysan motors with the following spec sheet and wiring diagram:
spec sheet
Based on that, and some posts in the forum referencing other boards with similar 2B2A1A1B labels on the board I'm planning on wiring the connectors as follows:
2B YELLOW
2A BLUE
1A RED
1B GREEN
From the other posts it seemed like I just needed to make sure I kept the pairs together and then if they were backwards I could just switch them in firmware right?
Thanks for any help you can provide!
Paul
