Hi all!
I have just finished my RepRap build. I bought a full kit, including soldering from MakerGear.com
When i started to power up, I started to talk with the people in the norwegian reprap forum, reprap.no
I started with after advice from the people there to use Sprinter firmware, so I uploaded that after I changed the firmware from 1.3 to 1.4...
I downloaded pronterface for the communication with the printer.
I have not connected the atx powesource yet, only usb, i have not connectet the heatbed to the RAMP pcb, and i have only one thermistor, that is to the hot end, the kit did not include a thermistor to the heat bed, and after some reading i couldn't find any concrete demands on that the heatbed needed one..
I connected the printer with com4 and the right speed, i pressed the "Get temp" and it gave me a reading of 45 degrees and the heatbed on abot 70 degrees.. (don't remember the exact numbers) keep in mind i have not connected any power to the printer, and the heatbed is not connected, and neighter is the thermistor for the heat bed..
Is there somting I am doint wrong, or is the card busted?
Thank you all
-Kjetil Hansen
