I hope all are well on the forum.
I have been troubleshooting electronics problems for a while now in a different thread bit now have identified a clear issue which i think deserves a new thread for then sake of clarity.
The problem with movement on my Y axis connection on my Gen 3 Electronics. I have been checking connections across different components (Stepper Drivers/MB/Ribbon Cable) but have now identified a possible cause of the problem.
When checking connection between Pin number 3 on the Y axis header and any of the ground connection pins, I see the following.
On a functional set of electronics
When pin 3 is connected to any of the ground pins, I see no change from '1' which suggests there is no connection between the pins.
On a faulty set of electronics
When pin 3 is connected to any of the ground pins the multimeter (at the 2M) setting begins at roughly .190 and climbs up to about .750.
I'm not electronically minded so if anyone could help explain what could be the cause of this, it would be appreciated.
Thanks to all.
Raj
