Help Arduino verify error November 12, 2011 06:08AM |
Could someone guide me in the right direction to get this working. I need help ASAP. I have a week left for this project in which i receive a grade for.Quote
GCode_Interpreter.cpp:66:24: error: RepStepper.h: No such file or directory GCode_Interpreter.cpp:67:24: error: LinearAxis.h: No such file or directory GCode_Interpreter.cpp:68:33: error: ThermoplastExtruder.h: No such file or directory GCode_Interpreter:63: error: 'LinearAxis' does not name a type GCode_Interpreter:64: error: 'LinearAxis' does not name a type GCode_Interpreter:65: error: 'LinearAxis' does not name a type GCode_Interpreter:67: error: 'ThermoplastExtruder' does not name a type GCode_Interpreter.cpp: In function 'void setup()': GCode_Interpreter:75: error: 'x' was not declared in this scope GCode_Interpreter:76: error: 'y' was not declared in this scope GCode_Interpreter:77: error: 'z' was not declared in this scope GCode_Interpreter:80: error: 'extruder' was not declared in this scope GCode_Interpreter.cpp: In function 'void loop()': GCode_Interpreter:112: error: 'extruder' was not declared in this scope GCode_Interpreter.cpp: In function 'void process_string(char*, int)': process_string:46: error: 'x' was not declared in this scope process_string:47: error: 'y' was not declared in this scope process_string:48: error: 'z' was not declared in this scope process_string:52: error: 'x' was not declared in this scope process_string:53: error: 'y' was not declared in this scope process_string:54: error: 'z' was not declared in this scope process_string:82: error: 'x' was not declared in this scope process_string:83: error: 'y' was not declared in this scope process_string:84: error: 'z' was not declared in this scope process_string:173: error: 'extruder' was not declared in this scope GCode_Interpreter.cpp: In function 'void ddaMove()': stepper_control:9: error: 'z' was not declared in this scope stepper_control:12: error: 'x' was not declared in this scope stepper_control:12: error: 'y' was not declared in this scope stepper_control:15: error: 'x' was not declared in this scope stepper_control:16: error: 'y' was not declared in this scope stepper_control:17: error: 'z' was not declared in this scope stepper_control:27: error: 'extruder' was not declared in this scope
Re: Help Arduino verify error November 12, 2011 10:15PM |
Re: Help Arduino verify error November 12, 2011 11:00PM |
Re: Help Arduino verify error November 12, 2011 11:16PM |
Re: Help Arduino verify error November 12, 2011 11:29PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Help Arduino verify error November 13, 2011 01:08AM |
Can you explain this process more clear?Quote
[github.com] You will have to rename the folder to match the name of the PDE file in the directory then you will be able to open it in the Arduino IDE.
are you talking about config.ramps-v1.2.h?Quote
You will also need to select one of the config files as a base and rename it as config.h . I would start with the ramps 1.2 config and change its pins to match your hardware.
Re: Help Arduino verify error November 13, 2011 01:35AM |
Re: Help Arduino verify error November 13, 2011 03:32AM |
In file included from /analog.h:15, from analog.c:1: /config.h:33:3: error: #error RAMPS has 1280/2560! set your cpu type in Makefile! In file included from /temp.h:4, from analog.c:7: /config.h:33:3: error: #error RAMPS has 1280/2560! set your cpu type in Makefile! In file included from /temp.h:18, from analog.c:7: /config.h:33:3: error: #error RAMPS has 1280/2560! set your cpu type in Makefile! In file included from analog.c:22: /config.h:33:3: error: #error RAMPS has 1280/2560! set your cpu type in Makefile!
Re: Help Arduino verify error November 13, 2011 03:53AM |
Re: Help Arduino verify error November 13, 2011 04:21PM |
New error:Quote
#if ! ( defined (__AVR_ATmega1280__) || defined (__AVR_ATmega2560__) ) #error RAMPS has 1280/2560! set your cpu type in Makefile! #endif Should read something like. #if ! ( defined (__AVR_ATmega168__) || defined (__AVR_ATmega328p__) ) #error xxxxxxx has 328 set your cpu type in Makefile! #endif
dda.c: In function 'dda_create': dda.c:236: error: 'DIO24_WPORT' undeclared (first use in this function) dda.c:236: error: (Each undeclared identifier is reported only once dda.c:236: error: for each function it appears in.) dda.c:236: error: 'DIO24_PIN' undeclared (first use in this function) dda.c:237: error: 'DIO36_WPORT' undeclared (first use in this function) dda.c:237: error: 'DIO36_PIN' undeclared (first use in this function) dda.c:239: error: 'DIO30_WPORT' undeclared (first use in this function) dda.c:239: error: 'DIO30_PIN' undeclared (first use in this function) dda.c: In function 'dda_start': dda.c:399: error: 'DIO42_WPORT' undeclared (first use in this function) dda.c:399: error: 'DIO42_PIN' undeclared (first use in this function) dda.c:402: error: 'DIO28_WPORT' undeclared (first use in this function) dda.c:402: error: 'DIO28_PIN' undeclared (first use in this function) dda.c:403: error: 'DIO40_WPORT' undeclared (first use in this function) dda.c:403: error: 'DIO40_PIN' undeclared (first use in this function) dda.c:404: error: 'DIO46_WPORT' undeclared (first use in this function) dda.c:404: error: 'DIO46_PIN' undeclared (first use in this function) dda.c:405: error: 'DIO34_WPORT' undeclared (first use in this function) dda.c:405: error: 'DIO34_PIN' undeclared (first use in this function) dda.c: In function 'dda_step': dda.c:482: error: 'DIO26_WPORT' undeclared (first use in this function) dda.c:482: error: 'DIO26_PIN' undeclared (first use in this function) dda.c:492: error: 'DIO16_RPORT' undeclared (first use in this function) dda.c:492: error: 'DIO16_PIN' undeclared (first use in this function) dda.c:499: error: 'DIO17_RPORT' undeclared (first use in this function) dda.c:499: error: 'DIO17_PIN' undeclared (first use in this function) dda.c:516: error: 'DIO38_WPORT' undeclared (first use in this function) dda.c:516: error: 'DIO38_PIN' undeclared (first use in this function) dda.c:526: error: 'DIO18_RPORT' undeclared (first use in this function) dda.c:526: error: 'DIO18_PIN' undeclared (first use in this function) dda.c:533: error: 'DIO19_RPORT' undeclared (first use in this function) dda.c:533: error: 'DIO19_PIN' undeclared (first use in this function) dda.c:550: error: 'DIO44_WPORT' undeclared (first use in this function) dda.c:550: error: 'DIO44_PIN' undeclared (first use in this function) dda.c:560: error: 'DIO32_WPORT' undeclared (first use in this function) dda.c:560: error: 'DIO32_PIN' undeclared (first use in this function) dda.c:657: error: 'DIO42_WPORT' undeclared (first use in this function) dda.c:657: error: 'DIO42_PIN' undeclared (first use in this function)
In file included from /analog.h:15, from analog.c:1: /config.h:33:2: error: #error xxxxxxx has 328 set your cpu type in Makefile! In file included from /temp.h:4, from analog.c:7: /config.h:33:2: error: #error xxxxxxx has 328 set your cpu type in Makefile! In file included from /temp.h:18, from analog.c:7: /config.h:33:2: error: #error xxxxxxx has 328 set your cpu type in Makefile! In file included from analog.c:22: /config.h:33:2: error: #error xxxxxxx has 328 set your cpu type in Makefile!
Re: Help Arduino verify error November 13, 2011 05:59PM |
Re: Help Arduino verify error November 13, 2011 08:11PM |
Re: Help Arduino verify error November 13, 2011 08:51PM |
Re: Arduino November 19, 2011 04:21AM |
Re: Arduino November 22, 2011 12:39AM |
Re: Arduino November 22, 2011 02:47PM |
