Check your gcode file, if it has lines that include Exxx.xx etc, then Skeinforge is generating the movements, but your hardware is not processing them.
If the E codes are missing, or zero, then check that you have Dimension activated in Skeinforge.
How often I found where I should be going only by setting out for somewhere else. - R. Buckminster Fuller
[apapageek.com]
