Z-Axis slipping?
Posted by schulz
Z-Axis slipping?
January 13, 2012 10:08PM
Hi everyone,
So I finally got the Z-axis going. Sort of. It keeps on slipping where the two nuts and spring are located. I've taped up the nuts so that they are really snug, however it still keeps on slipping. Is it OK to super glue them in?
Here are some pics:
Cheers,
Schulz
Re: Z-Axis slipping?
January 13, 2012 10:23PM
You shouldn't need them to be snug, in fact at least the top nut needs to be free to slide or the spring is useless. The bottom nut should be underneath the x end. There should be no possibility of it sliding since it rests on the bottom nut.
January 13, 2012 10:51PM
Oh wow,
Ok thanks! fixed it now, its all good now smiling smiley
January 14, 2012 11:08AM
For the benefit of others with a similar problem what did you do?
January 15, 2012 09:06PM
Haha, ok,
So bellow the X-Ends, there is actually a Nut holder, which is obviously where, one M8 nut is supposed to go (silly me!) This allows the tension of the spring inside the holder, and the top nut, to make sure that the aforementioned problem does not occur, due to the tension created by the bottom of the X-Ends and the top nut.
quite a good design grinning smiley
Schulz
January 15, 2012 09:31PM
I make mine with the top and bottom nut's tight and no spring, they go up and down really nicely. Attached is the idler .stl for my linear Prusa's
__________________________________________________________________________
Experimenting in 3D in New Zealand
open | download - X idler Lin mk2.STL (69.8 KB)
