changed y pully tooth#
Posted by glrra19
February 10, 2012 02:51AM
ok broke my y pulley, so ive robbed one off my prusa.
im going from 8 to 12 teeth
i can do the math i just cant get it to save right or something.
or do i upload?
orca3, gen6 arduino marlin pronterface
Re: changed y pully tooth#
February 10, 2012 04:46AM
should i ask questions somewhere else?
February 10, 2012 04:55AM
Take a look here - from Chapter 3 onwards
Basically you should just need to load the sketch, change Configuration and compile (Ctrl+r) and then download to the board.
Make sure you have the FTDI Drivers installed (for the USB to serial link) and that the Arduino is set to the correct Serial port and board/CPU.
[richrap.blogspot.com]
February 10, 2012 04:57AM
thanks richrap ill try that
February 10, 2012 05:19AM
You may also find this tool useful (to check your maths) [calculator.josefprusa.cz]
February 10, 2012 05:38AM
i dont know i think im gonna have to re install or something
i cant even find a .pde file
i must not have the right configH
couse it never compiles
February 10, 2012 06:02AM
If you're using Arduino 1.0 the file will be a .ino instead of .pde
February 10, 2012 06:27AM
omg! when i renamed marlin.ino to marlin.pde
it started doing stuff again!
February 10, 2012 06:40AM
smiling smiley that wont have been necessary if you're using arduino 1.0, in which case it will rename it back to .ino when you save, which is fine!
So all you need to do is update the steps for whichever axis pulley you changed and re-upload!
February 10, 2012 06:48PM
i think i have to use a different version.
cause when i looked at version 1 there was no sanguino otion under tools.
i think thats just a gen6 thing.
