Will a Xylotex board work with Reprap software? January 25, 2011 09:20AM |
Re: Will a Xylotex board work with Reprap software? January 25, 2011 09:44AM |
Re: Will a Xylotex board work with Reprap software? January 25, 2011 11:01AM |
Re: Will a Xylotex board work with Reprap software? January 25, 2011 02:43PM |
cannot answer your question but the plastic components look good - are they milled? They don't look printed
You don't specify which Xylotex package or driver models you have. According to this page, it's designed to run of STEP and DIR signals from a computers parallel port. If that's also the case with your setup, it'll be relatively easy to use with a reprap. Well, as long as the motors mount to the frame OK.
You will need to add the following:
An MCU, or microprocessor board, usually an arduino mega, a sanguino, or such. More rarely, PIC or ARM based boards are used, but you'll have problems finding a firmware to load onto those.
A temperature sensor & heater controller. Usually just a couple resistors & a thermistor for the sensor, and a MOSFET to control the heater. You may want two of each for a heated bed. You can also use a thermocouple and a MAX6675 chip for temperature sensing.
Endstops. Cannonically optical, but microswitches work fine too.
To get these together, the easiest thing to do may be to buy a bare RAMPS board and a arduino MEGA clone. Then buy the thermocouples, MOSFETS, and supporting LEDs, capacitors, and so forth. It should be fairly straightforward to figure out from the schematics. At first guess, you need power stuff (C4, C6, F1, D1) Thermistor 0 (R7, C5) Heater 0 (Q3, R4) and err, that's about it. So 2 resistors, a MOSFET, 3 capacitors, a diode and a fuse. Oh, and the thermistor of course. You'd wire the Xylotex stepper drivers into the step and dir signals on the RAMPS shield, probably easiest to install two pin headers where the pololu stepper drivers would normally mount. Probably have to tie grounds together too.
Please note that I'm no expert on these things, my real specialty is software. But I'm pretty sure that'd be the easiest way to go. The pololu stepper drivers that this RAMPS thing is designed to work with cost about $12 each, so you'd be saving $48 plus shipping, plus the cost of the motors plus shipping. Assuming you have a 4-axis driver with four motors, if not you'll need to buy one pololu stepper driver + one more motor for the extruder.
Re: Will a Xylotex board work with Reprap software? January 25, 2011 03:22PM |
